BMW Garage | BMW Meets | Register | Search | Today's Posts | Mark Forums Read |
BMW 3-Series (E90 E92) Forum
New Vanos Recall (23V-707)
11-19-2023, 09:38 AM | #45 |
Rep 465
11-19-2023, 10:34 AM | #46 |
Rep 90
Drives: 2010 BMW 328i xDrive
I have an appointment for an oil pan gasket replacement next month at my independent shop. Is there any chance a bolt could be sheared off and exhibit no symptoms? My VC was off a few months ago for an ESS replacement by the same shop and they didn't say anything about the bolts. Hate to pay for the OPG replacement if there are broken bolt heads, and the dealer would take care of the replacement under the recall.
Know this isn't that common of a failure, but also would suck if the bolts break after doing the OPG and before having the recall addressed. Valve cover gaskets shouldn't ever be reused, so they better be replacing that. |
StradaRedlands5033.50 |
11-19-2023, 10:44 AM | #47 |
Rep 3,088
Drives: 2006 BMW 330i MT
Garage List 2006 BMW 330i [8.25]
2009 BMW 328i Touri ... [8.00] 2013 BMW X5 35i [7.80] 2011 BMW 528i [8.70] 2006 Mazda3 [5.50] |
Cpet Would be great if your dealer could do the recall first and see if there is a problem. Probably a small chance of a bolt sheared off, but it's possible.
Cpet133.50 |
11-19-2023, 10:46 AM | #48 |
Rep 1,187
Exactly- if there’s even a chance BMW will foot the bill, why pay first? How badly is your OPG leaking?
StradaRedlands5033.50 Cpet133.50 |
11-19-2023, 11:38 AM | #49 |
Rep 401
Drives: 2011 e91 328i RWD
You can scope the Vanos bolts through the oil filler with a common USB inspection camera. Rotate the crank with a socket wrench, and see if the Vanos bolts are all there. 4 each on the back of the intake and exhaust Vanos units. The exhaust ones typically fail first but they all need replacement according to the RCRIT procedure.
Also, the faulty torx bolts have a center security pin. The replacement bolts are just normal torx bolts. Last edited by Mike K; 11-19-2023 at 11:44 AM.. |
11-19-2023, 12:21 PM | #50 |
Rep 90
OPG isn't horrible, been leaking for years and leaves a drop when I park. However, my tie rod ends seized, messed up the alignment, and the tires are wearing unevenly causing annoying road noise. So going to do everything at once: OPG, motor mounts, tie rods, tires, and alignment.
11-19-2023, 12:26 PM | #51 |
Rep 90
Good to know, thanks. The car only has 73k on it and runs like new. I'm guessing no issues. If I don't end up getting a camera, hopefully the dealership will be truthful if any are broken and drop the pan. However, would like to do the tires + OPG sooner than later, and who knows how long until the dealers are ready to perform the repair.
11-19-2023, 04:34 PM | #52 | |
Rep 2,529
Drives: 2011 328i Wagon
I figure the dealer techs would have done a TON of these the last go-round, so should be plenty familiar with the process, and certainly R&R of valve covers has to be bread and butter for them, and that is most of the work here. I mostly trust my dealer - they did a bit of shoddy warranty work in the beginning which I raised Hell about, every time they have touched the car since it has been done properly. I suspect there is a "note in my file' that this guy is a fussy bastard who WILL check your work, so unless you do it right the first time, you will get to do it again for free.
'11 328! Touring - Tasman on Chestnut, 6spd manual, factory upside-down "i" option '11 128i Convertible - Space Gray on Savannah Beige, 6spd manual, also '14 Mercedes-Benz E350 wagon, '95 Land Rover Discovery, '74 Triumph Spitfire |
StradaRedlands5033.50 M-technik-32135.50 |
11-19-2023, 04:37 PM | #53 | |
Rep 2,529
mct128i74.50 |
11-20-2023, 02:11 PM | #54 |
Rep 2,151
My car is 06/2009 production date and when I inquired with BMW Canada, I got this reply:
"While we understand your concerns, our system does not indicate that your vehicle's engine was affected by this recall. As previously advised, recalls provided by BMW Canada are Vehicle Identification Number (VIN)-specific and are based on factors such as production dates, part affected, etc. Therefore, not every vehicle of the same year and model will be subject to the same recall. We hope you find this information helpful." Can any BMW insiders pshed some light on the Vanos bolts? Was it just a certain batch for the specific production run and that is why 2006 - 08/2009 N52 is not affected? I'd be happy with that confirmation. |
11-21-2023, 03:40 PM | #55 | |
Rep 194
11-21-2023, 05:53 PM | #56 |
Rep 483
Drives: Break My Wallet
I think BMW Canada's database is either not up to date or bullshit because it doesn't correspond to Transport Canada's info on the recall that says 2011 vehicles - 3 series is included.
My car is MY2011 and it says there are 0 open recalls for my car. |
11-22-2023, 06:27 AM | #57 | |
Rep 194
https://recalls-rappels.canada.ca/en...ll-2023568-bmw Havent checked BMW Canada yet though |
11-29-2023, 06:26 AM | #59 | |
Rep 345
11-29-2023, 06:28 AM | #60 | |
Rep 345
My 2011 N51 328xi is covered by the recall. it was done in the 2010 recall too. |
11-29-2023, 09:11 AM | #61 | |
Rep 4,109
Since my 3/2007 N52K E91 was built BEFORE the earliest build date subject to Recall, I have NOT used my USB Endoscope to view VANOS bolts. I have several questions: 1) Can you see the Top-2 bolts on BOTH the Intake Cam & Exhaust Cam using scope? Some have reported (perhaps incorrectly ;-) being UNable to see one VANOS unit with scope. 2) Did you save image file (jpg, etc.) of Scope screen, and if so can you attach it? 3) What Make/Model Scope (USB I presume ;-) did you use? 4) I presume you can use that scope with either a laptop (USB A connector) or phone (USB C connector)? I have a cheap Endoscope from Amazon (see link below) that has light but image definition is NOT the greatest. If we can exchange details to help folks be able to inspect in 5 minutes without removing VC, I'll take the time to save jpg ScreenPrints, and post here. https://www.amazon.com/Seesi-Endosco...7&sr=8-10&th=1 ANYONE know if there is a NEW RCRIT, or if the one related to 14V-176 (attached) still applies? If new RCRIT, please attach pdf, or provide link. Be aware that the attached RCRIT (pdf p.14) provides for VANOS Unit replacement if ANY of its 4 bolts is loose/broken: "If any of the bolts were loose or broken during this procedure, the VANOS assembly will need to be replaced. Refer to step 14." There is also provision in earlier RCRIT for finding broken bolts (pan removal if necessary). I don't recall seeing anything more than BOLT replacement mentioned in new Recall documents appearing thus far. ANYONE having recall performed SHOULD request copy of BMW's recall procedure, and ask what was actually DONE. The Devil is in the DETAILS, George |
StradaRedlands5033.50 Marine568110.50 |
11-29-2023, 03:11 PM | #62 |
Rep 401
Hi George,
I always appreciate your valuable input to this group and you really helped me through this a couple of years back. At that time, I pulled my VC so I didn't need to scope it. But it seemed to me then that you could scope in through the oil fill and at least see if a given Torx Vanos bolt has the center security pin which would indicate the presence of faulty bolts. The replacement bolts are just normal Torx bolts. I don't know of a new RCRIT as I used the one you had supplied back then. I'm awaiting the mailed recall so I can plan my next move as I completed the repairs a few years back. |
11-29-2023, 03:18 PM | #63 | |
Rep 401
Since then, I have done 3750 mile oil changes with Liqi Moly engine flushes each time which has greatly reduced that sludge seen on my old youtube. The car runs silky smooth now. We all know that the typical DPAs are just that; "Damned Previous Owners!" |
12-09-2023, 09:02 AM | #64 |
Rep 483
So the previous owner of my car had the timing chain and guides replaced at an indy mech. What are the chances that the vanos bolts were replaced? I don't have the service records for it but I found the info from Carfax.
Reason I ask is, if it's possible that the bolts were replaced, I would not have to do the recall at a BMW dealership. |
12-10-2023, 03:03 PM | #65 | |
Rep 35
12-10-2023, 08:40 PM | #66 |
Rep 5
I own a 2010 F10 528i with N52 from Australia and I have received the recall for the VANOS bolts.
Unfortunately, 4x bolts already failed 2 years ago so I went ahead and replaced all 8 of them myself with the updated part. I've still booked the recall in with BMW but have not yet disclosed to them that they have already been replaced as they failed previously. While I am not too concerned about being reimbursed for the bolts and VCG (although it would be nice), I have always been concerned about the 4x missing bolt heads that were never retrieved from the motor. Fortunately, the engine has lasted up until this point however is it worth having a discussion with the technician regarding the retrieval of the bolt heads? I assume they will not want to go through this process, although I do have photos of the broken bolts. Do you think once I disclose they've already been replaced, they won't want to take on the job at all? |
