08-20-2014, 07:41 PM | #67 | |
Rep 1,031
Drives: 335 E92 DCT
Have you figured out how to remove the head light sensor alert that pops up at night? so annoying! because fo the front camera blocking the sensor |
08-21-2014, 03:09 AM | #68 | |
Rep 4,021
Drives: F32 Coupé
09-06-2014, 02:43 PM | #69 |
Rep 43
Used this thread to install mine today. Only issue was that fuse 5 on my car seemed to be live all the time. Fuse 7 seemed fine though so used this with a piggyback device.
It is a UK car though, so perhaps that why. |
09-07-2014, 07:15 PM | #71 | |
Jedi samurai ninja turtle
619
Rep 3,021
Drives: X3 M40i 2018
The headlight sensor is Uber annoying though!!! |
09-07-2014, 11:17 PM | #72 |
Rep 4,021
Drives: F32 Coupé
I actually haven't had that problem Ian.... Got any pics of how/where your camera is mounted? Could it be differences between the E82 and E9x?
09-08-2014, 12:11 AM | #73 |
Rep 1,514
I've mounted mine at the top of the winscreen to the left of the rear view mirror to avoid any issues with the hi beam assist sensor, also just had the top of the winscreen tinted to help hide where the camera sticks on the screen.
It doesn't look like the OP has the HBA sensor hence why no issues with the camera position: Last edited by Prodigy.; 09-08-2014 at 12:20 AM.. |
09-08-2014, 04:59 PM | #74 |
Rep 43
Just remove the screw from behind the airbag cover plate and then pull the panel up not out. There are 2 upside down U shaped clips that hold in place. Just need to apply a bit of horizontal pressure when refitting to make sure it locates properly, took me a couple of attempts to get the top clip in.
01-01-2015, 06:41 PM | #75 |
Rep 643
Do you guys know which side is the hot side of the fuse port? I used a multimeter with a thin wire and tested both sides and can not get continuity. For ground I'm using that bolt. I hooked it up to slot 64 with 5A fuse for the battery power wire to the power magic pro and it works.
01-01-2015, 07:08 PM | #76 |
Rep 36
what size memory cards are people using in the Blackview?
also, does this price seem fair? http://www.ebay.com.au/itm/BLACKVUE-...item4add53f12d |
01-02-2015, 04:07 PM | #77 |
Rep 113
Its about the right price, I got mine here but on a group buy with the 16 & the 32GB memory card paid just under $380.
http://www.streetfx.com.au/product/n...dent-recorder/ |
01-09-2015, 08:51 PM | #78 | |
Rep 36
01-14-2015, 12:21 AM | #79 |
619
Rep 3,021
Found a cheaper one for you guys:
http://carboncarsystems.com.au/free-...-dash-cameras/ I use them for all my in car tech, camera and remote start/tracking that I've got installed. |
01-18-2015, 05:19 PM | #81 |
Rep 1,054
I'm liking the 650 myself. Would love front and rear. Not sure on if power magic pro required though. Would prefer battery to turn itself off at a certain voltage Ala Volphreaks Lithium Ion. Saves stuffing about with wiring
01-18-2015, 05:41 PM | #82 |
Rep 902
I'm looking at getting the bang for buck alternative, G1W-C $55 USD
It has a capacitor for those high heat Melbourne days! Anyone got any idea how to hardwire it and hide the cables though? |
01-18-2015, 07:58 PM | #83 |
Rep 334
01-18-2015, 08:04 PM | #84 |
Rep 1,054
01-19-2015, 01:30 AM | #85 | |
Rep 396
Front and Rear
All came good in the end with a top quality repair job and no excess to pay but it would have been a he-said, she-said issue with the insurer if not for the witness. If I had the rear view camera at the time, it would have been priceless to see the look on her face as she out drove her ability. The audio would have been nice to hear too seeing as she came right up to my window after the event. What a potty-mouth mole she was too. |
01-20-2015, 06:58 AM | #87 | |
Rep 902
Any DIY guides on the fuse box? |
01-20-2015, 04:08 PM | #88 |
Rep 187
All of them can plug into the cigi lighter. Parking mode is just being stationary for 10 mins and goes into parking mode to record movement.
You don't have to use it.
2006 E87 130i
M3 front and rear arms, M3 Front and rear ARB , Quaife LSD, BMW performance wheel (non electronic), 135i Brakes, DS2500 pads, Apex wheel studs, Adjustable Bilsteins, API Half cage, Hankook Z221's (track) and Bridgestone RE002's (street) 225's all around |
Tags |
black vue, camera, dash cam, onboard cam |
