08-08-2020, 05:02 PM | #1 |
675
Rep 1,778
High oil and coolant temps, low oil pressure - new Rad and Accusump
Did my hottest track day yet...95F at The Ridge in Shelton WA. Finally experienced the coolant temp power reduction that others have mentioned. Saw over 280F oil temp, 250F coolant temp, and IAT's to 170F. Trans temp also got to 250F. Caused me to install a CSF radiator yesterday. Next track day is Thursday...hope it's hot again so I can get a good comparison. May need to upgrade my dual oil cooler setup as well.
https://datazap.me/u/andyw/very-hot-...ata=5-12-14-19 https://datazap.me/u/andyw/very-hot-...a=5-7-12-14-19
Best,
Andy '12 E82-PS2,Stoptechs,Clubsports+M3 bits,Accusump,Wagner DP+EVO III FMIC,ERCP,BMS Intake,Mason Strut Bar,Wedge Tune Last edited by AndyW; 08-12-2020 at 07:20 PM.. |
08-09-2020, 03:58 AM | #3 |
675
Rep 1,778
Yes. On a previous track day I had indications the vents were definitely helping.
Best,
Andy '12 E82-PS2,Stoptechs,Clubsports+M3 bits,Accusump,Wagner DP+EVO III FMIC,ERCP,BMS Intake,Mason Strut Bar,Wedge Tune |
08-10-2020, 08:48 AM | #4 |
Rep 216
Really interesting to see your logging over a whole session. I plan to do the same at the end of the month for a track day.
I am interested in your oil pressure logging. It looks like you dipped below 30 psi at the same point on the track for each lap. From your logs, it looks like this was a heavy braking section into a slow part of the track, maybe the downhill switchbacks toward the end of the lap? It's pretty low pressure, but you're also at low rpms, so maybe nothing to worry about? Any thoughts? |
AndyW674.50 |
08-10-2020, 09:21 AM | #5 | |
Rep 2,028
See timestamp 865.47. He is at 0% pedal input, 2400rpm, 48psi (sounds about right since 40psi is idle). The next two data points he is accelerating and oil pressure is dropping. Not a good sign. As for the overheating, seems like a really slow course that you're dropping to the bottom of 2nd gear. Radiator should help a lot since you're an automatic. if you do a comparison log, make sure it's at the same track because that can have a huge influence on temps. |
AndyW674.50 |
08-10-2020, 09:55 PM | #6 |
675
Rep 1,778
Sigh...now I'm worried about oil pressure...lol. I had been considering an Accusump. Maybe I need to pull the trigger. Which turn is worse for oil...left IIRC. There is a large left sweeper on that track where my VIRB data indicates 1.3-1.4 g's. There is also the "thumb" turn which is a short, tight left hander.
Which pressure switch should I get with the Accusump? 35-40 seems optimal to prevent discharge at idle... |
08-10-2020, 10:03 PM | #7 | |
675
Rep 1,778
08-10-2020, 10:58 PM | #8 |
675
Rep 1,778
Nevermind...found it on the other site..forgot some of the discussion there.
Pulled this interesting data from the log (removing idle time at start and finish) % Time less than 40 psi 5% Longest time less than 40 psi 4 Sec % Time less than 60 psi 18% These are very different than my numbers from last fall. Low pressure points are definitely in the slowest left hand corner. So, what is the concensus on need for a check valve?...I plan to tee in to the return line from my driver side oil cooler. Last edited by AndyW; 08-11-2020 at 12:31 AM.. |
08-11-2020, 09:55 AM | #9 |
Rep 216
An accusump is high on my priority list as well. Which is why I took an interest in your data logs. From what I have seen, the 35-40 psi valve is suggested as the most common application, but I think bbnks2 did the 55-60 psi valve. This brings up an interesting question, because if you look at your datalogs, it appears like the accusump would be discharging 5-6 times per lap using the 35-40 psi valve, and possibly another 1-2 more times if you use the 55-60 psi valve. I assume that using one of the EPC electric valves kit which allows for "fast" refills of the system would be sufficient to refill the accumulator and have it ready to discharge again, but I don't really know.
I plan to take logs of the next couple of track days in which I won't have an accusump, and then hopefully can install one over the winter break and compare with new logs as the same track with an accusump. |
AndyW674.50 |
08-11-2020, 10:19 AM | #10 | |
675
Rep 1,778
Best,
08-11-2020, 11:09 AM | #11 |
675
Rep 1,778
I guess I need to understand the consequences of forgetting to turn it off and it dumps the oil to the sump...what am I risking dumping 3 extra quarts to the sump?
Best,
08-11-2020, 01:41 PM | #12 |
Rep 216
If you do the wired 12V control, do you still have to manually turn it off before turning the car off? I know the benefit of the wired 12V option is that you don't have to turn it on, but maybe that doesn't work the same for turning it off?
08-11-2020, 05:17 PM | #13 | |
675
Rep 1,778
the system is at 40 psi so the Accusump will dump. That is why bbnks2 has a switch to turn the system on while going on the track and turning it off while leaving the track. |
bbnks21212.50 |
08-11-2020, 06:02 PM | #14 |
Rep 2,028
I have the 60psi electric valve. I wired it to a manual switch so I can turn the Accusump off for street driving. I flip the switch on as soon as I roll onto the track. My thought process was that I should never really be below 3,000rpm/60psi on track anyway so I went with the 60psi valve.
The risk is that at idle (40psi) the accusump electronic solenoid would be open. Constant open voltage on the solenoid tends to burn it out quickly. I think Accusump addressed that specific issue though many years ago when they moved to a new electronic valve. But, that is a valid risk... burning the solenoid out. The Accuusmp doesn't just dump all of it's oil at <60psi. I have a 3qt unit. If pressure falls to 40psi it will probably only discharge 1-1.5qts. Another 1.5-2qts of oil will still be in equilibrium in the accumulator. It takes pressure dropping down to less than the 7psi air bladder pressure for it to fully discharge all 3 qts. So long as there is more than 7psi of oil pressure the accumulator will always have some level of oil in it. At 20psi pressure it might fill with 1qt... and 100psi it might even cram as much as 3.5qts in. Hope that helps conceptualize how the oil pressure drives how much oil get's pushed into the accumulator... and then the dropping pressure allows that oil to slowly feed into the system to equilibrium when the solenoid opens. I don't think a check valve will really do anything. I think the positive displacement oil pump will prevent any backflow. My logs show the accusump feeds into the block when the car is even fully OFF (builds over 60psi) so the oil pump and oil filter is preventing backflow even when the cars not running and no oil is flowing from the oil pump. Last edited by bbnks2; 08-11-2020 at 06:09 PM.. |
AndyW674.50 |
08-11-2020, 11:38 PM | #15 | |
675
Rep 1,778
- Accumulator has a 7-10# bladder pressure..the air pressure that will vacate all the oil. For this to happen, system pressure would have to go to essentially zero. So full discharge is not realistic in an operating (vice prelube) scenario. - The control valve will always let system pressure push oil into the accumulator as long as system pressure is above the EPC valve setpoint. It functions as a check valve when the EPC is below it's setpoint. So oil will fill the accumulator to 90# (basically max out put pressure) and somewhere between 2 and 3 quarts. - When pressure falls below the EPC setpoint, the EPC allows flow toward the system and flow rate will be based on the D/P. So, if the setpoint is 60#, that is a 20# D/P initially, with a reducing flow rate as D/P goes down due to the Accusump piston moving due to the D/P. Assuming system pressure continued to head toward 40# the Accusump will keep emptying until it equalizes with the system with some remaining volume in the tank (the only way the tank empties if if system pressure gets to 7-10#, which would be "Game over" while moving). This leads me to believe the earlier the oil starts flowing as you move toward a minimum system pressure, the better - you have more time to push oil into the system before a critical point is reached (lets pick 40# as the red line since that is around idle pressure, as that seems to be the concensus). If we picked the 35-40# EPC valve, the initial pressure between the tank and the system is greater when the valve opens, so the flow rate will be higher than if you were using the 55-60# EPC valve, but the discharge for the 35-40# EPC is much closer to danger when it starts helping. I need to see if Canton has any flow rate vs D/P graphs. It may be moot. All of my events are less than 4 seconds. i.e. If the Accusump discharges from 80# to 40# in 2 sec and 80#-60# in 3 seconds, I think it's a wash. I am going to see if there is any data or graphs on the rate at which the Accusump discharges. Once site I looked at said the 3Qt gives "15-60 sec" which seems extremely optimistic. Without knowing flow rates it is difficult to know.
Best,
houtan707.00 |
08-11-2020, 11:46 PM | #16 |
675
Rep 1,778
This guy doesn't even use a valve... http://www.billavista.com/Tech/Artic...ing/index.html
This guy uses it on an airplane and gets 6-8 seconds https://vansairforce.com/community/s....php?p=1098370
Best,
Andy '12 E82-PS2,Stoptechs,Clubsports+M3 bits,Accusump,Wagner DP+EVO III FMIC,ERCP,BMS Intake,Mason Strut Bar,Wedge Tune Last edited by AndyW; 08-11-2020 at 11:52 PM.. |
08-12-2020, 12:20 AM | #17 |
675
Rep 1,778
Ordered my Accusump stuff. Hope to install next week. got the 55-60# EPC. Am going to go wireless for the power switch. https://smile.amazon.com/gp/product/...29BIB8JL&psc=1
Best,
08-12-2020, 01:29 PM | #19 | ||||
Rep 2,028
I could log oil pressure at 3,000rpm/60psi and once the light flights on to show it's dumping I can see how long the oil pressure stays up above say 50psi. Then do the same test again with no accusump. I posted a few autocross logs where you can see 25psi lows bumped up to 40-50psi lows with the Accusump and that was enough data for me lol. How quickly it discharges is really going to be relative to how much volume the accumulator is being asked to make up for. Last edited by bbnks2; 08-12-2020 at 01:34 PM.. |
AndyW674.50 |
08-12-2020, 06:34 PM | #20 |
675
Rep 1,778
Interestingly, if I had followed Canton's flow chart I'd have purchased a 2 qt (based on 6 cyl) and 20-25# EPC (based on idle oil pressure of >25# but <40#). I sent an email to Canton asking about this and the flow rate question.
08-12-2020, 11:07 PM | #21 |
675
Rep 1,778
Looks like it is going to be 20F cooler (i.e. more normal) at the track tomorrow...will make it harder for a great temp comparison.
Best,
08-14-2020, 12:18 AM | #22 |
675
Rep 1,778
So, some data from today's track time.
https://datazap.me/u/andyw/tnia-ridg...zoom=3244-8730 The good news is: No limp mode! It helped that ambient temp was 77F vice 95F --- 18F less. Two other changes were in play. 1. I did an oil change - new oil was 5W-40 vice 5W-30 (believe this may have helped oil pressure a small bit after looking at the data) 2. I finally sealed the new vented hood from the cabin air intake area - so less backpressure for air flowing from the coolers and then up and out the vented hood. Looking at peak temps from last time with a linear normalization for ambient temp diff in parenthesis: Oil - 282F (264F) Coolant - 250F (232F) Transmission - 250F (232F) IAT - 193F (175F) Today Oil - 264F Coolant - 234F Transmission - 234F IAT - 170F It seems whatever changed from the new radiator appears marginal. I really need another hot day to really compare and that's unlikely to happen this year. I think the only thing I can say for sure is that I did no harm and the new radiator definitely has more capacity than the old one - I know just driving it on the street makes oil temp 10F cooler than it was before...so it is doing something. The good news is that oil pressure seems more under control. Interestingly, There was slightly more time less than 55# but there was a lot of traffic in this session so that may account for it (less time on max throttle). % Time less than 35 psi <1% Longest time less than 40 psi 3 sec % Time less than 55 psi 15% Will hopefully have the accusump installed before the track day next Friday and will report back.
Best,
