      08-27-2019, 12:10 AM   #1
mikeypx82
Drives: BMW 135i
E82 135i No communication possible with: Dynamic Stability Control
My DSC is no longer responding but I don't have any warning lights on the instrument cluster. I'm getting Code S 0085, No communication possible with: Dynamic Stability Control in ISTA and no response from control unit in INPA. I checked all of the fuses associated with the DSC and ABS (Fuse 4, 26, 90, 82) and all of them are OK. I checked the DSC harness and it's plugged in securely. Not sure why the DSC would die suddenly. Is this a common problem for E82's? Can this be fixed or does it have to be replaced?
      08-27-2019, 07:10 AM   #2
Edrift
Drives: BMW 135i E88
Did you change anything on the car recently? Flash something? Code something?
Flat battery?
Wash the engine bay?
      08-27-2019, 07:48 AM   #3
mikeypx82
Drives: BMW 135i
According to ISTA the DSC error message appeared 300 miles ago. Nothing was changed, flashed or coded at that time. Last thing I did to the car was code CIC for some combox related stuff but that was way before I noticed DSC malfunction.
      08-27-2019, 12:21 PM   #4
dtla1
dtla1's Avatar
828
Drives: 2011 135i, Space Grey
My guesses, 1. dying battery 2. Steering Angle Sensor needs to be cleaned.
      10-26-2019, 05:06 AM   #5
juld0zer
Is the control unit actually dead in ISTA (yellow control unit)?
So imagine you'd have a christmas tree of lights on the cluster too?
      02-29-2020, 08:43 AM   #6
Bradypus
Bradypus's Avatar
Russia
Drives: BMW e82 120d
mikeypx82 Had you fixed the issue? I have the same error on my 120d.
      06-25-2020, 02:06 PM   #7
Bradypus
Bradypus's Avatar
Russia
Tnx to markllhughes from e90post.com for his advice
This happens when you run tests with only have basic Ignition On.
Press START button without starting the car to engage ignition stage 2.
i.e. Engine lights on etc.
Run test, should now read DSC OK.
Worked fine for me And so easy
abs, dsc
