03-05-2017, 09:55 PM | #1 |
Rep 24
Misfires - could it be caused by my dinan tune?
My car has been having misfires lately causing the vehicle to go into limp mode. The dealership suspects its the Dinan Software that was recently installed. But I recall the car doing the same thing at least once prior to the Stage 2 software install.
Has anyone been having any misfire issues? With or without a Dinan tune that make your vehicle go into limp mode? This has happened to me at 3 times within the past few weeks. and once prior to my software install. Each time I was in a high gear cruising most recently I was in 4th gear at about 4000 rpm shifting to 5th when the car misfired and went into limp mode. Im concerned about my safety as the engine vibrates and the throttle becomes inactive while I am on the highway city street. Ive been in such a position multiple times, one time my son was with me.
2011 135i | Space Gray | DTC | Dinan Free Flow Exhaust | Dinan Stage 2 Software Tune | Dinan Stage 2 Suspension
03-05-2017, 10:18 PM | #3 |
Rep 100
read codes what cylinder
2011 135i DCT
Space Gray Metallic | TR Motorsports 17x8 ET40 Wheels | Koni Yellows | FMIC | Charge Pipe | MHD Stage 1 | Riken Raptor 245/40ZR Tires |
03-05-2017, 11:10 PM | #4 |
Rep 105
No issues here either (S2 for a week), but the tune will definitely work those components a little harder. If there were issues with the coil packs or spark plugs, the tune may not be the cause, it's just revealing the need to have those items replaced.
Here's hoping it's a simple replacement exercise. |
03-06-2017, 08:35 AM | #5 |
Loves me some MHD!
1861
Rep 1,725
What codes are pulled?
Age of plugs/coils? Less likely, but injectors age? Are you doing any maint, or all dealer?
1and1
135i - E82.N54 2009 BSM - MHD / xHP / DCI, PR CP & 7.5" Race IC / N55 mid & Borla . . WL RSFI, Koni, Eibach & Dinan CP's, M3 CA's / EBC Red's & Firehawk 500's X1 - E84.N20 2013 MGM - JB4 - The Wife's, now with new turbo & ewg |
03-06-2017, 09:03 AM | #6 |
Rep 322
Agree. Probably spark plugs, possibly coils. If you have at least 20k miles on your current plugs, I'd replace them full stop. If you have 60-80k miles on the coils, they're also coming up on their expiration date.
03-06-2017, 12:32 PM | #7 |
Rep 1,547
Agree with the above, start with the easy possible fixes first and try and find the root of the problem.
2014 BMW X5 xDrive 35d M Sport Mineral White
2011 BMW 135i M Sport Space Grey 2007 Suzuki GSX-R 750 |
03-06-2017, 01:01 PM | #8 | |
Rep 638
with new cars you have got to get the codes, otherwise your pissing in the wind
coil packs can go without warning, they just go and boom but without knowing what codes there throwing your just guessing Quote:
03-06-2017, 05:07 PM | #9 |
Rep 24
They said they replaced the injectors, coils and plugs within the past couple of weeks. The car is still having the stated issue. They said most recently that they removed the software and couldn't duplicate the issue. Thats the reason I asked if anyone else was experiencing the same issue. They replaced the software prior to returning the car to me.
I do not know what to do. I don't feel safe at all. The vehicle dit it today.
03-06-2017, 05:09 PM | #10 |
Rep 24
I have the codes. They happened to leave a worksheet in the car. I will get them and post them shortly.
jaye9441014.00 |
03-06-2017, 05:44 PM | #11 |
Rep 24
The codes I see on the sheet say 2EE0, 2EE4 and 2EF1. I don't know if I am reading correctly.
I don't know if its saying the DTC also has a fault. They haven't mentioned anything about that.
03-06-2017, 06:59 PM | #12 |
Rep 322
I got the 2EE0 and 2EF4 codes yesterday while logging for a tune. In my case it's almost certainly because I didn't gap my spark plugs closely enough. First (and hopefully last) time I've ever gotten a misfire. You're positive they replaced your plugs and coils recently? Those two are responsible for the far majority of misfires as I understand it. Since you're still having issues, might be worth asking them to double check their work. The plugs seem likely since the frequency of misfires has gone way up since you put the tune on (which ups boost, and is harder on your plugs).
2EF4 is cylinder 6, 2EF1 is cylinder 5, for what it's worth. 2EE0 just notes misfires on multiple cylinders. But I'd ask that they check all 6 plugs. I replaced mine with factory plugs recently and they were allegedly pre-gapped, but they were WAY off. |
03-06-2017, 08:47 PM | #13 |
Rep 100
I had a new plug that was bad and misfiring. diagnosed it by moving coil and plug and watching if the code moved. replaced that new plug with another new plug and that fixed it.
2011 135i DCT
03-07-2017, 01:30 AM | #14 | |
Rep 24
Thank you, I will ask them about such today.
03-07-2017, 01:33 AM | #15 |
Rep 24
All maintenance has been done by one dealership or another one closer to where I used to live. They said they recently changed the plugs, coils and injectors.
