12-26-2017, 03:21 PM | #1 |
Rep 553
Noticeable Drone for BMW PE (Performance Exhaust)
Hope everyone is having an amazing holiday season!
I've had the PPK1 software and BMW Performance Exhaust for almost a year now and I've been loving it for the most part. I've noticed that during regular driving in automatic mode with light throttle inputs (low RPMs), there is quite an amount of drone. There's enough drone to the point where it can get uncomfortable sometimes. I'm not sure if this is normal for a BMW performance product so I'm here looking for all of your experiences! My car is a 2012 BMW 135 with N55 and DCT. It has no modifications other than the PPK1 and PE. |
12-26-2017, 03:40 PM | #2 |
Rep 22
I've got a 6 speed, PPK & PE and notice no drone.
Might be because of gear selection, DCT might be going to too high of a gear resulting in drone? |
12-26-2017, 03:49 PM | #3 |
Rep 3,085
Drives: 991.2 Porsche GT3, BMW E46 M3
Garage List 1987 BMW 325is [10.00]
2004 BMW X3 [6.50] 2018 Porsche 911 GT3 [10.00] 1974 BMW 2002tii [10.00] 2004 BMW M3 [10.00] |
Might be the PPK.. I have a 2011 DCT with MPE and VRSF catless Downpipe and have no drone.
Follow me on IG
Garage: 2018 991.2 GT3|2013 135i|2004 M3|2004 X3|1987 325is|1987 325i|1974 2002tii |
12-26-2017, 04:31 PM | #4 | |
Rep 7,227
It comes from cruising around in auto mode and letting the RPMs dip too low. I have the DCT and the PE (with y-pipe) and drive in manual mode and if I start to hear any drone I just downshift and it goes away. Manual mode plus sport button is the only way to drive a DCT equipped car in my opinion. Makes the car come alive.
BAN_M2C4190.00 ByeByeVTEC24.00 |
12-26-2017, 04:56 PM | #5 | |
Rep 553
In the summer time, I drive in manual mode 90% of the time. In winter when it is nasty and snowy out, I could careless about driving sometimes so I just leave it in auto. |
12-26-2017, 05:06 PM | #6 | ||
Rep 7,227
12-26-2017, 06:36 PM | #8 |
Rep 7,227
12-26-2017, 09:05 PM | #10 | |
Rep 7,227
Personally wouldn't do it because I'd be afraid that I might lose some of that beautiful exhaust sound by keeping/adding the resonator. That's why the y-pipe is included when you buy the Performance Exhaust. Gives you the option of adding it or not. At least it was included when I bought mine.
12-27-2017, 06:19 AM | #11 |
Rep 132
Esteban, did you lose the notorious burbles after the dinan? I did and didn't think I would care but starting to miss that once in awhile.
2012 DSB e88 135i Dinan S2
12-27-2017, 06:36 AM | #12 |
Rep 7,227
No, I didn't. Honestly, think they sound a little more aggressive. Sorry to hear that you did. Are you N55? And yes, I would miss it as well.
12-27-2017, 02:25 PM | #13 |
Rep 553
Well, now that I know that it's normal as others are experiencing this drone, then I am okay with it as I'll try to drive in manual mode more often in the winter time.
I just wanted to make sure that my setup wasn't faulty. |
Esteban44366.50 |
12-27-2017, 03:49 PM | #14 |
Rep 177
I drive in manual mode 90% of the time so no drone. If I don't feel like paddle shifting then I slide the shifter to S and let the car shift. It keeps the rpms above 2000 and a gear lower than D which usually takes care of any drone.
Esteban44366.50 |
12-27-2017, 03:56 PM | #15 | |
Rep 7,227
12-27-2017, 06:28 PM | #16 |
Rep 3,085
@Esteban do you have the MPE midsection also?
I might not get the drone you guys are having because I kept the stock mid section.
Follow me on IG
12-27-2017, 09:24 PM | #17 |
Rep 7,227
Yes sir, I have the y-pipe/resonator delete (as mentioned above). It came with my BMW Performance Exhaust and adds a little more volume. Very happy with this setup. As I said above, any drone I get is controllable, so not a problem for me.
BAN_M2C4190.00 |
12-28-2017, 05:24 PM | #18 |
Rep 166
The PE and PK2 was fitted when i got the car 2 years ago and i did notice the drone cruising at 100 kmh. two years later it doesn't really bother me
12-29-2017, 01:53 PM | #19 |
Rep 553
When cruising around 100-120km/h and going up a slight uphill on the highway in full automatic and super light throttle input, your revs should be +/- 2,000rpms. Does it produce ANY drone there?
01-05-2018, 04:14 PM | #21 |
Rep 338
Drives: 2013 BMW 135is
Own 135is. Drone is very present at 2000rpm. That’s basically the drone sweet spot. The more throttle and the more you’re at 2k, the louder it is. You have to get above 2300rpm for it to go away. Which usually means downshifting a gear or two. Pretty annoying.
Unfortunately, it’s getting to me. There’s also some other potential exhaust related noises and vibrations going on that disturb me as well. Literally can feel it in my seat and through the arm rest sometimes. Thought it was the driveshaft or flex disc or csb but I had the flex disc and csb replaced. Drive shaft seemed fine too. Vibration still happens only when gears are engaged. Pretty annoying. The exhaust is just kinda obnoxious at this point. It’s good sometimes but I’ve gotten over it. It’ll never be like when I first bought the car. Heh. |
