E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > Anyone know what this leaking part is?
Reply
      03-27-2024, 02:50 AM   #1
trickster123
Drives: 2007 e92 325i 2.5L
I was doing an oil change and whilst i was underneath i noticed all this oil but not sure where its came from and what part that even is. E92 325i n52n
      03-27-2024, 11:05 AM   #2
Phil325i
Phil325i's Avatar
Drives: E92 325i MSport Coupe
I'd guess at crankshaft main rear seal. The oil is leaking from the mating surfaces between the engine and gearbox, plus maybe the sump gasket, though that could be blow-back...
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
      03-29-2024, 06:33 PM   #3
crashoverride
Drives: na
Many guesses can be made. However unless you are physically looking at the car it makes the guessing game extra challenging. The best advice for leaks is to take your car down to the local spray and pray car wash throw a can or two of engine cleaner under the ol bonnet and clean things up.
Oil and other liquids have a nasty habit of starting at one spot and ending up at a completely unrelated other spot. It also gives you the ability to see is this a big leak or so slow that the years of build up fool you into thinking it's worse than it actually is.
Reply
e90post
