04-13-2020, 12:24 PM | #1 |
Rep 1,058
Items to get CK'd before Warranty Expires?
Hello 1M Members!
So, I have less than 3 months before my warranty expires on my 1M. I'm taking her in for the blower motor recall and the front fender liners in a couple of weeks. So, thought I'd CK to see what other items I should have them look at while it's in the shop? Currently has approximately 11K miles and I replaced the Charge Pipe and both Turbo Bypass Valves (Pressure Converter?) last August. Any guidance will be greatly appreciated |
04-22-2020, 09:10 PM | #9 | |
Rep 1,058
With respect to the warranty, the original owner first leased and then purchased the car. When he purchased it, he also purchased the extended the warranty. So, that coverage is about to expire in July. So, was just trying to figure out what things I should focus on? Although, car is running like a champ! So, I'm sure something will bust the day after my warranty expires....lol! |
04-22-2020, 11:51 PM | #10 |
Rep 30
Hi Tornado,
My 2012 also has about 10K miles on it. I've done everything on the car myself including coilovers, brakes, exhaust, bushings, vacuum hoses, etc. My consensus is that after 10K miles and 8 years, none of the OEM parts we in need of replacing. All rubber bushings were intact, OEM rubber hoses were in good condition. This is assuming that the car is garaged and indoor most of the time. My HPFP and Index 7 or 9 (can't remember which but definitely not 12s) are still fine. You have done the CP which is an obvious one. Fluids are a must but I'm sure you're up to date with normal maintenance. The only thing that went bad on my car was the OEM Bosch Spark Plug. I had the plug on cylinder 6 went bad (misfiring). That was right after I bought the car around @ 4000 miles. Then recently cylinder 3 OEM Bosch plug also went bad. I always keep spare plugs in the garage, they are cheap. Other than that the car has been very reliable!
|2012 AW 1M Coupe| |MHD Stg 2| |Ohlins R&T| |BBS RI-D| |VRSF CP| |VRSF 7" HD| |Tial BOV| |Akrapovic Full Evolution Exhaust System + DP| |AP Racing Radical II| |Raceseng Slammer| |Pedalhaus|
04-23-2020, 06:16 PM | #11 | |
Rep 1,058
Very much appreciated 🙏 |
