      12-22-2018, 07:28 PM   #1
greensto
Wild Card
greensto's Avatar
Drives: 1M Conversion
Help: Turn Signal Light Stays On
Hey guys,
Could really use some help trying to figure out an issue I'm having with my passenger headlight. The actual amber turn signal bulb stays solidly lit when my car is either on or off. I have an error light on my dash that just let's me know that there is an error, but my turn signal arrow isn't illuminated or anything. Lowbeams on both sides work fine as does the driver side turn signal light. I have disconnected the headlight so my battery doesn't drain, but I am not sure what's causing the issue. I replaced the bulb and cleaned around the contact area, but no change. TIA!
Basically looks like this when I turn the car off
Name:  Screen Shot 2018-12-22 at 8.32.53 PM.png
Show me a sane man and I will cure him for you.
      12-24-2018, 09:21 AM   #2
greensto
Wild Card
greensto's Avatar
ttt
      12-24-2018, 09:19 PM   #3
Gangplank
Gangplank's Avatar
2011 135i  [0.00]
I know this is a dumb question but have you checked the position of the light switch? Is in the parking lights setting?
      12-24-2018, 09:44 PM   #4
Esteban
Esteban's Avatar
Drives: a slow car fast
Bad fuse?
      12-24-2018, 09:56 PM   #5
NorthernDancer
check the left/drivers side bulb and socket very carefully. Especially look for a bad ground.
      12-25-2018, 02:17 PM   #6
greensto
Wild Card
greensto's Avatar
Same symptoms in all positions, unfortunately.
      12-25-2018, 02:17 PM   #7
greensto
Wild Card
greensto's Avatar
Bad fuse?
Which fuse would that be for a turn signal light on just one side?
      12-25-2018, 02:18 PM   #8
greensto
Wild Card
greensto's Avatar
Tried looking around, but what should I be looking for exactly?
      01-01-2019, 08:30 AM   #9
Fantastipotamus
Drives: 2015 M4 Vert DCT
Could be the Footwell Module (FRM)? Apparently it can be to blame for weird light issues. My ‘08 would turn on the reverse lights and parking sensor anytime I hit the brakes.
Warranty was apparently just extended for these (edit: only certain model years, mine wasn’t covered).. info here: https://www.1addicts.com/forums/show...light=Footwell
Gangplank1541.50
      01-02-2019, 06:48 PM   #10
dtla1
dtla1's Avatar
828
Drives: 2011 135i, Space Grey
Honestly I just came in here to find jokes related to BMW and Turn Signals, but none where found. I would also suggest FRM module but have no idea how to check if it's bad or not. Any issues with the power windows?
      01-13-2019, 03:54 AM   #11
Lester
Drives:
This issue can only be solved by tracing where the voltage is coming from. A relay or switch that should be turning the voltage off is shorting out or not working. This is not easy to do without a Chilton or equivalent manual with a wiring diagram.
It's likely not a fuse, as a fuse not working will simply turn off the power for that circuit.
2008 135i, Jet Black, 6 spd, Canadian Sport package, black leatherette, manual seats, aluminum glacier trim, PDC.
1983 E21 Delphin, M10, 5 speed, LSD, MSW wheels, recaro seats, Hartge strut brace, rear sway bar.
[SIGPIC][/SIGPIC]
      01-13-2019, 04:35 AM   #12
Gangplank
Gangplank's Avatar
2011 135i  [0.00]
A quick google search found this thread on a similar issue with an e90. It sounds like the FRM module & reprogramming is the answer.
https://www.e90post.com/forums/showthread.php?t=679894
This should be covered under the extended FRM warranty which was extended to 10 years/156,000 miles.
FRM Footwell Module warranty extension.
https://bimmerscan.com/wp-content/up.../B012016-1.pdf
      02-03-2019, 08:20 PM   #13
greensto
Wild Card
greensto's Avatar
Thank guys, turned out to be my the footwell module. However, my manufacture date is a couple months after the window of the recalled vehicles
