05-12-2015, 06:52 PM | #1 |
Rep 39
JB4 Install: All of a sudden 29F2/2B2C Codes!
I installed my JB4 and ran fine for about 72 hours. Now I throw 29F2 and 2B2C codes after the engine is warmed up and I hit 3k RPM.
This happens regardless of what map I set it to, and did not happen when I was driving the car hard. I've tried adjusting the open loop settings (Speedo 11) and adjusted everywhere from 60-100 with no luck and the same results. I've updated the firmware on the JB4 to the latest firmware as well. Worst part is, this even happens on Map 0 with the JB4 disabled. Can anyone help? Any ideas? |
05-12-2015, 06:57 PM | #2 |
1Addict
3233
Rep 7,894
Have you reinstalled the JB4 yet? Does the car throw codes with the JB4 uninstalled completely?
Has your car had the HPFP replaced? Are you using E85 in your tank?
05-12-2015, 07:27 PM | #3 |
Rep 39
I haven't tried to uninstall completely. I did attempt to reinstall. I'll try that next.
HPFP has not been replaced but it showed 0 signs of stutter or any other issues prior to this (63k miles). The car would turn over on ignition faster than any car I've owned. No e85. |
05-13-2015, 12:08 PM | #5 |
Joint Chiefs of Staff
24183
Rep 190,777
+1
05-13-2015, 09:10 PM | #7 |
Rep 2,037
Garage List 1994 Porsche 968 Cab [0.00]
2017 AMG GTS [0.00] 1994 Porsche 968 Coupe [0.00] 1977 Mercedes 450SE ... [0.00] 2008 135 [8.00] |
My Hpfp went out right after I installed a piggyback. Was difficult to figure out what had happened.
