      01-26-2018, 09:19 AM   #1
SnowGlobe
Drives: Mazda MX-5
New Double Din solution from Metra!
Correct me if I am wrong - but it looks like metra has made a double din kit for the 1 series. I've just seen a press release for a new MOST adapter as well.
There is also an instruction manual I've linked it all below. Dated 1/11/2018
Press release for new turbokit dash kits : https://metradealer.com/news/index/v...0-turbokits-ce
1 Series dash kit : http://www.metraonline.com/part/95-9315B
Seat heater relocation: http://www.metraonline.com/part/98-9306
Instruction for Dash Kit: http://www.metraonline.com/files/pro...-9315B_web.pdf
The radio is a bitter lower than optimal, but this is definitely a plus over a single din only!
edit: MOST adapter is AX-BM90122
      08-13-2018, 12:06 PM   #2
jamespaoli
Drives: 128i
Where is the LCD screen / Radio purchased?
      08-14-2018, 01:03 PM   #3
HyeWarrior
Drives: 2012 135i DCT
Pretty sure this kit lets you install most of units sold at like Best Buy and such
      08-15-2018, 11:41 AM   #4
jamespaoli
Drives: 128i
Thanks man... Do you know anyone who has some info or has done these retrofits? Curious what ill need for a seamless install on avin usa they have tons of options for extra wires etc
      08-16-2018, 08:33 AM   #5
Stubbie Blue
Drives: 2012 135i Coupe
First thing is if you have the iDrive screen or not. I don't have iDrive, so I don't know that much about the options to upgrade it, but I think they are all pretty expensive ($800+).
Instead, I installed this single DIN Android headunit:
https://www.1addicts.com/forums/show....php?t=1510420
Single DIN is much easier than double DIN because double DIN requires you to cut some plastic behind the dash (look at the instructions for that Metra 95-9315B kit), and the screen will be located very low. If you try a BMW E90 3 series or another kit that has the screen on top and the climate controls on the bottom, I believe the 1 series has 2 screws on the sides that won't clear the climate controls.
However it is hard to find single DIN headunits with a screen. Ones with a flip out screen like the Pioneer AVH-3300NEX would cover the air vents. For a fixed screen, there's the Joying headunit that I got, the Alpine iLX-F309 ($900), or even the Alpine iLX-207 ($600) might work but the bare metal chassis and screen will stick out from the dash.
Then you need a smart wiring harness to retain warning chimes, steering wheel controls and PDC.
If you don't have Harman Kardon, you can use the PAC RadioPRO RP4.2-BM21 ($120), like I did.
If you do have HK, it uses a fiber optic MOST bus amplifier so you will need one of these $300+ harnesses:
AXXESS AX-BM90122
Connects2 CTSBM012.2 (search on eBay)
      08-20-2018, 08:20 PM   #6
jamespaoli
Drives: 128i
Hey Stubbie.. Yep i dont have iDrive.. i have nothing haha.. goal is to to get the LCD/Backup cam working without losing functionality
      10-01-2018, 07:17 PM   #7
Cpplilballer
Drives: 2003 Z4
Has anyone officially bought the double din? How was fitment? Were there any issues with the relocation of the climate control? Thank you!
