01-21-2011, 09:09 PM | #1 |
Rep 955
Which plug and play chip is reliable and has the LEAST gain?
im looking for something that is plug and play where i can take it off and put it back on without to much difficulty on my 135i. but has minimal gains, i dont want to mess up my car cause it has 58k miles on it but want the extra punch needed. TIA
01-21-2011, 09:11 PM | #2 | |
Rep 268
Look in sales section of forums |
01-21-2011, 09:48 PM | #5 |
Rep 3,274
You can open up the casing on the JB+ and dial it to different amounts of gain. On the lowest possible setting it's only like 25 hp I think. Otherwise you could get an old JB1 or JB2 but I'd honestly just go with the JB+ because you won't have to deal with plugging in anything into the ECU. Even on stock setting and up to 100% power the JB+ has not given me any error codes either.
2022 X4 M40i - 2008 135i - 2015 F700GS On Order - 2024 i4 M50 Scruffy's gonna die the way he lived... Mmhm. |
01-22-2011, 09:15 PM | #8 |
Rep 409
Drives: 2008 Montego Blue 135i
One more for the JB+ I got one and its got the power that I wanted. My 1er is fast enough for me. I'd rather concentrate on the suspension and exhaust.
There are no impossible deeds, only incapable men.
Eibach frontsway,BMS JB4,AFE Drop InBerk Street Axleback, H&R SPORT SPRINGS,Active Autowerke DP's ,Active Autowerke BOV,Active Autowerke FMIC , BMWPEDALS.COM, JB SPEED Black Grills,Alpina B3 TCU Flash |
01-23-2011, 09:32 AM | #10 | |
Rep 1,406
Drives: 2020 SO - M2C
Cobb tunning ( very easy to remove and install..just use access port thats located in side of the car) see http://www.1addicts.com/forums/showthread.php?t=479054 for install and uninstall |
01-23-2011, 02:09 PM | #11 |
Rep 340
The JB+ is a great value. I had it installed for 14 months; mostly on 100% and never had any problems with codes (I have the BT cable to check). The increased power was very impressive; especially in the mid and high RPM ranges. You can get a good used one for under $150.
2019 911 GTS
2017 M4 CV 2017 Mini JCW |
01-23-2011, 03:30 PM | #12 |
Bulldog
482
Rep 3,355
ESS DirectFlash
I just got the ESS Direct Flashon my 135i that is completely stock and I would definitely recommend it. The ease of use and ability to return to stock anytime along with great hp gains is just a win win IMO.
Prev: Individual F80 M3 - Fjord Blue/Silverstone(interior) | Fashion Grey(exterior)
GTS |
01-23-2011, 03:34 PM | #13 |
Rep 5,689
Just flash it and I wouldn't expect any tune to cause any issues with just a tune.
01-24-2011, 10:17 PM | #14 |
M Power
41
Rep 1,469
JB3 or JB4, run on lowest setting, and depress accelerator only 3/4s of the way down. The less you depress, the less the HP you will generate.
