      12-17-2010, 04:51 AM   #1
Zuzu
Zuzu's Avatar
Drives: M2C HS 6MT
JB3 caution
For those of you who are running the JB3 on the higher maps (7 and UP ) beware..
I have heard from a friend who has been running map7 constantly that he has thrown a cel code, limp mode.. Engine check light came up with"Engine Failure" warning with reduced engine power.
For those with a BT tool the code thrown was-
30FE:/30FF:
30FE Exhaust fume turbo charger,high pressure side.
EXPLANATION: ECU boost over ECU target.
FIX:Generally related to tuning. It may be a sign to reduce boost level or disable LAGFIX.
Also can be caused by boost leaks, leaky DV's, broken vacuum lines etc.
They replaced the sensor and now car good as new..
      12-17-2010, 07:49 AM   #2
ozzie135i
Thank your friend for this good advice!!! I hope that the bmw service guys don't follow this forum LOL
      12-17-2010, 09:40 AM   #3
Jeef Beef
Lord Captain Commander
Jeef Beef's Avatar
Drives: a sleeper
Do not run map 7 on 98RON gas! Terry recommends max map5 on US 93 which is equivalent to our 98RON.
Also, this is where the advantage of PROcede comes in. It won't run the boost if the car can't handle it.
E82 135i M-sport: SGM/6MT/Black
      12-17-2010, 10:16 AM   #4
JHOOPS2
AKA HISSMAN
JHOOPS2's Avatar
Drives: 2009 SG 135i Coupe'
What mods did he have?
(FBO) Cobb Stage 2+, AR Downpipes, Injen DCI, AA (Sport) FMIC, ER Chargepipe/Synapse BOV, Carbon fiber bits and Breyton GTS-R Wheels.
      12-17-2010, 05:28 PM   #5
Zuzu
Zuzu's Avatar
Drives: M2C HS 6MT
Hi Jeef..I didn't post to debate the whole JB3/Procede pros and cons..
Just a code ID post..
Map7 is safe to run on our 98RON, as he has been running Map7 for the past 18months with no probs until now.
      12-18-2010, 05:43 AM   #6
fontana302
Drives: 2012 E90 M3
I had that one on Map 5 - was a leak at high boost.
      12-19-2010, 12:06 AM   #7
WOPALX
WOPALX's Avatar
Drives: 335i Sedan
Pretty common code if the tune is too harsh for the mods or conditions encountered.
30FE:/30FF:
Vishnu PROcede V5 | VK Motorworks FMIC | AR Design OCC | Forge DV's | Bilstein PSS9 | M3 Lower Control Arms & Caster Rods | Quaife LSD | HiTech Exhaust | BMW Performance Illuminated Door Sills | BMW Performance Gear Selector & Boot | BMW Performance E-Brake Cover
      12-19-2010, 02:07 AM   #8
Orlin
Orlin's Avatar
Drives: F30 335i
I agree its common and it is not related to only one tune because I have had it. I cleared the code and have not yet been back to BMW as the car seems to be running fine for now and I am due for a service soon anyway.
      12-19-2010, 02:47 AM   #9
Zuzu
Zuzu's Avatar
Drives: M2C HS 6MT
The first time this code was thrown, it was cleared with the BT tool and car was fine.. Four weeks later, same code came up, but this time, 20% in power reduction noticed at WOT, hence off to the dealer for inspection and replacement of faulty turbo pressure sensor.
      12-19-2010, 03:20 AM   #10
Orlin
Orlin's Avatar
Drives: F30 335i
apart from the jb3 is the car stock? hopefully mine does not come back however I think it will unless I either decrease the boost level or get some supporting mods.
      12-19-2010, 03:32 AM   #11
Zuzu
Zuzu's Avatar
Drives: M2C HS 6MT
PM sent..
