10-05-2009, 06:56 PM | #1 |
Rep 1,025
Drives: G08 iX3
Windows wind half-way down when opening the door? [FIXED]
Usually when I open the door, the windows come down about a cm and rise up again when I close the door. However sometimes the window winds over half-way down (both driver and passenger doors). Why is this happening? Is there a setting I can change to 'fix' this behaviour?
edit: fixed by changing the unlock door setting from 'convenience' to 'drivers door' Last edited by chylld; 10-05-2009 at 08:37 PM.. |
10-05-2009, 07:10 PM | #2 | |
Rep 3,016
If you put your windows all the way up before opening the door, then turn the car off completely, it will stay up when you re-open the door when you get back in |
10-05-2009, 07:15 PM | #3 |
Rep 1,025
Drives: G08 iX3
Yeah that would be normal operation; but sometimes, even if the doors were fully closed on the previous trip, instead of coming down just 5-10mm it will go over half-way down!!
10-05-2009, 07:22 PM | #4 | |
Rep 9,156
10-05-2009, 07:24 PM | #5 |
Rep 1,147
the windows will go down halfway when you open the door when you press the unlock button twice which unlocks the passenger door and the boot as well. i think you can programme the key not to do this but i have never bothered.
10-05-2009, 07:26 PM | #6 |
Rep 1,025
Drives: G08 iX3
I will have to play with the unlock settings... now that i think about it, this has only happened when i press the unlock button twice to open the passenger door as well. Thanks for the tip!
10-05-2009, 07:29 PM | #7 |
Resident Kerbalnaut
477
Rep 10,703
If it comes down halfway then your window motor's ECU is blow and it needs to get replaced. I just had mine replaced and and the issue went away. If it only pops down a few mm then dont worry about it. Its normal.
10-05-2009, 07:30 PM | #8 |
Rep 1,092
Drives: F82 M4 CP
I've been wondering this too. I knew that you needed to press the button twice, but couldn't quite work out what this feature is for. I just put it down to German engineers with too much time on their hands.
While on features I haven't quite worked out yet, how do you get the headlight washers to come on? They seem to come on randomly whenever I use the windscreen washers. Also, is there a way to change the date reading on the audio headunit so that it reads in an Australian way (ie. 6/10/09 instead of 10/6/09)?
2017 BMW M4 Competition - Mineral Grey
2009 BMW 135i - Titan Silver - SOLD |
10-05-2009, 07:34 PM | #10 |
Rep 1,025
Drives: G08 iX3
10-05-2009, 07:37 PM | #11 |
Rep 1,474
Drives: 135i MT, LMB, ProNav
I concur with you.
Fun Car: 135i Manual LeMans Blue / Beige Leather / Grey Poplar / pro nav / euro plates. Delivered 24 June 08 Family Car: Land Rover Discovery 4 SDV6 Spare Car: Volvo V70 Sydney Car: MB 420SEL |
10-05-2009, 07:50 PM | #12 |
Rep 685
Window half-way down --- it'll do it when you press unlock twice. You can change the unlock setting to unlock everything with one press. So you can have the passenger door unlocked without the window coming half -way down.
Headlight washers --- you activate them when you wash the windscreen, and the headlights are also on. |
10-05-2009, 07:54 PM | #13 |
Disillusioned bourgeois capitalist pig!
21
Rep 488
I know i'm being small and petty ( I tore all the ligaments in my right ankle so carnt drive ATM), but has anybody READ THE MANUAL!!! Pages 18 to 26.
Sorry - I feel better now....
You can lead a fool to knowledge but you cannot make him think!
10-05-2009, 08:27 PM | #14 |
Rep 1,092
Drives: F82 M4 CP
Sadly no business or professional nav in my lil' car. I guess I'll just get used to be reading the date like an American.
10-05-2009, 08:36 PM | #15 | |
Rep 1,025
Drives: G08 iX3
1) all doors 2) driver's door 3) convenience changed it from 3 to 2 and all is well!! |
10-05-2009, 08:36 PM | #16 |
Rep 208
It is definatley a setting that can be changed. I played with all the settings when i got the car, inface i think my hubby has this setting on his key. Its soo annoying if he uses it. I turned it off straight away my key setup.
www.driverdynamics.com
10-05-2009, 08:44 PM | #17 |
Rep 1,025
Drives: G08 iX3
sounds like i'll have to change it for my fiance's key as well thanks for the heads up.
10-05-2009, 09:12 PM | #18 | |
Rep 238
you beat me to it. I think it even says in there that the feature is there to allow for more room to get in/out of the car in a cramped spot. I like the feature - it stops passengers from closing the door by pushing/pulling on the glass (leaving fingerprints everywhere) instead of the door itself. |
10-05-2009, 09:12 PM | #19 |
Rep 1,147
does it say anything about headlight washers, they are definately on some kind of counter even with the headlights on.
10-05-2009, 09:17 PM | #20 | |
Rep 1,025
Drives: G08 iX3
Curious though, how would winding the windows down help in a cramped spot? If there is a car next to you, ........ OHH I see now. Will check the manual tonight. |
10-05-2009, 11:34 PM | #21 |
Rep 839
I hate the headlight washer sprays. You clean the car, have the driving lights on. quick spray to clean the windscreen and bam, water all over the car from the headlights
'09 BMW 135i, Lemans Blue
'97 Nissan Skyline R33 Series II GTR V-Spec |
10-05-2009, 11:52 PM | #22 |
Rep 3,016
