05-14-2013, 10:09 PM | #1 |
Rep 2,409
DIY: Installing F10 M5 shift knob on 135i
I read a few posts that people were looking for a DIY on the F10 M5 shift knob. I decided to make the purchase. I have a 08 135i Mtech, and prem package, nothing else.
Step 1) Put car into 2nd gear and using both hands pull upwards to remove the oem knob. Once the knob is off the shifter, you'll want to remove the shift boot. The boot is removed by pulling up on any corner, theres 4 tabs one on each corner. Step 2) You will now see the bare shifter, there is a 5x4x2 foam square piece you'll remove. Just lift up at the corners and it'll come out. Step 3) Get your M5 shifter, turn the boot inside out, you will see a white ring. Tug and pull on the leather boot and it will slowly come apart where its glued. Then you'll want to use a small screw driver or something to break the two oval tabs on the white ring. Theres no way of removing the white ring without breaking these 2 tabs. Step 4) Right around 4th gear, you should see an electrical connection. I'm not sure where it leads to/from, but its connected to the headlights/interior lights. I noticed its live when the headlights are on and turns off when car door is opened. Step 5) Disconnect the connector by pressing the two tabs on the side. There are 3 wires on the connector, brown (ground), green/yellow (unsure), red/purple (power). You'll want to tap into the Brown wire and the red/purple wire to power the led light on the M5 shift knob. Its pretty simple since the shift knob has the same color wires, brown, red/purple. Use whatever method you're comfortable with tapping the wires. (Soldering/wire tap/strip and electrical tape) Step 6) Once you've made the electrical connections for the M5 knob, you'll want to take the white ring you removed in Step 3. You'll take it and push it into your oem shift boot. Push it up from the bottom side... DO NOT push it all the way through, you want to place the white ring 1cm below the very top of the leather boot opening. Hold the ring in place and use glue to secure it in place, I used super glue. (Make sure the ring is pointed straight, the broken taps should be pointed towards 4th gear) Now you'll want to install the foam square, then the leather boot, and then the shift knob, finally the interior trim piece. Final As I said, the knob will turn on if the headlights are on, and it will turn off if you turn off the car and open the door... The M5 knob feels different in the hand, but after driving for a day, I'm really starting to love how it feels, shifting feels much better too. Here is the Purchase Link $123 shipped |
05-15-2013, 09:17 PM | #3 |
Rep 2,409
05-15-2013, 11:13 PM | #4 |
Rep 961
Sorry totally missed that!!
05-16-2013, 12:21 PM | #5 |
Rep 339
Make sure you disconnect the battery before tapping into the wires. I didn't and it triggered airbag light (not sure how..), which I had to live with for weeks before I had it cleared.
05-16-2013, 04:36 PM | #6 | |
Rep 2,409
I didnt disconnect the battery and didnt receive an airbag light.... but it is advised to disconnect the battery when doing electrical work... this shifter feels so much better than oem, I swear the gearbox feels smoother!!! |
05-16-2013, 07:29 PM | #7 |
693
Rep 3,266
Drives: 2010 128i
So our cars are pre-wired for this? I wonder why? I don't recall seeing a wiring harness when I changed out my shift boot (but that was a few years ago...) - is it hidden under the "5x4x2 foam square" you talk about?
____________________________ |
05-16-2013, 08:02 PM | #8 | |
Rep 2,409
Its not pre-wired for it, because the m5 knob has a small connector on the end of the wires, which you cut off and then use the wires to tape into the wire harness I showed in the DIY. Yes I believe ALL 1 series have this white connector, which we tap into for power, I even saw it on an Automatic 1 series... Once you remove the boot, you should see a loom of wires running to the right of the shifter, if you follow those wires, you'll have to remove the big foam piece then you'll see the white connector... Here is a picture I found online of the foam piece... |
08-09-2013, 01:02 AM | #9 |
Resident Tamed Racing Driver
298
Rep 4,697
Just as an update, if you have a 2010 at least the wiring is nothing like this. It looks like I need to run one from the fusebox to the center stack. I'll post an update when I do.
08-09-2013, 09:20 AM | #10 |
Rep 2,409
Post a picture of your wiring. Maybe my diy only works for cars with a cigarette lighter, I believe some 1 series dont have an ash tray.
08-09-2013, 11:37 PM | #11 |
298
Rep 4,697
I don't have an ashtray, but I do have a 12v outlet under the armrest.
I'll get pictures up when I work it out. I would really like to have it on night time switched power.
08-12-2013, 12:05 PM | #12 |
298
Rep 4,697
So I did a bit of digging and Red/Grey wires are universally interior lighting(what you want for auto dim and night on off). You have one because the ash tray has interior lighting. Figuring there would be one for the radio and climate control, I pulled off the center stack trim and looked around inside.
Bingo, hiding in the wiring harness. I tapped it with a vampire clip as there was no room to solder and ran a a lead back up the center console to the shifter. Soldered it together at the knob and then tapped the ground that was in the center console already. Perfect function with dimming to the OBC controls. Functions as if stock. Last edited by TheSt|G; 05-22-2014 at 12:40 PM.. |
08-12-2013, 12:10 PM | #13 |
Rep 2,409
05-22-2014, 11:13 AM | #14 | |
Rep 45
Thanks, CM |
05-22-2014, 12:43 PM | #15 | |
298
Rep 4,697
The trim I removed was the climate control piece that extends down and wraps under the center stack. Expect to break/bend it on the way out, it's a flimsy hunk of junk. I replaced it with a new one.
05-22-2014, 02:55 PM | #16 |
Rep 45
04-11-2017, 06:14 PM | #17 |
E82 Mudflap Ambassador
2214
Rep 2,219
Drives: '08 128i
Interested in doing this, anyone know where to get the knob inexpensive?
Parents' 2014 528i - Mineral White/Ivory White - fully loaded Instagram @Andreys_128i and @Honda.Bito |
04-11-2017, 06:22 PM | #18 |
Rep 486
desertman123
https://www.getbmwparts.com/partloca...catalogid=4462 https://www.ecstuning.com/b-genuine-...FZWCaQodKj0KFQ https://www.fcpeuro.com/products/bmw...m5-25112284205 First result has a few other OEM options.
