06-25-2010, 04:08 PM | #3 |
Rep 1,552
Why can't there be any companies based in Hawaii?
2019 M2C - Alpine White - 6MT
2023 Supra 6MT - Deposit and Wait |
06-25-2010, 04:44 PM | #4 |
Let's save military ranks for those who earn it!
45
Rep 1,161
Drives: ...on the Ragged Edge
So, as it's just one turbo, wouldn't be just a downpipe?
Richard
2013 BMW M3 Individual -- Fire Orange (sold) 2013 BMW X1 xDrive35i M-Sport -- Valencia Orange (sold) 2011 BMW 1-series M Coupe (#205/220) -- Valencia Orange (sold) 2009 BMW 135i M-Sport Coupe -- Space Grey (sold) |
06-25-2010, 04:52 PM | #6 |
Rep 601
+1. one turbo=one downpipe. should bring downpipe prices down to the $3-400 range for N55 owners.
--2009 BSM 135i-- -Manual, Sport Package, BMW Assist |
06-25-2010, 08:07 PM | #7 |
Rep 4,936
i think it should be pretty simple. I figures AR would have something going already. From what it seems like their are twice as many sensores on the new n55 then on n54 witch i would guess complicates things. And yes we will probably be seeing the most high end pipe going for no more the $300
[SIGPIC][/SIGPIC]
06-25-2010, 09:46 PM | #8 | |
Rep 126
Edited to add: Below is a pic of an internally wastegated (as on the N55) twinscroll turbo. Last edited by Future M1 owner; 06-25-2010 at 10:04 PM.. |
06-26-2010, 01:31 AM | #9 |
BOSS
11
Rep 83
If you were closer to ny...
06-26-2010, 07:19 AM | #10 | |
45
Rep 1,161
One exhaust impeller, one intake impeller. Exhaust in (via exhaust manifold aka header), exhaust out (via downpipe). Intake in (via intake system), intake out (via intake piping, usually to intercooler). One turbo, one downpipe.
Richard
06-26-2010, 10:03 AM | #11 |
Rep 13
For a "Twin Scroll" Turbo, there should be 2 Cold Side Air Inlets, 1 Main Hot Air Out (Both Compressor Wheels Combined), and 1 Main Exhaust Out (Both Compressor Wheels Combined).
But it Looks like the Turbo on the N55 is not Sequential, so there will only be 1 Cold Air In, 1 Hot Air Out, and 1 Exhaust Out. So...1 Air Intake, 1 Charge Pipe, 1 Downpipe.
07 Silverado 2500HD - EFI Live/Corsa Exhaust/Injen Intake/EGR Blocker/TTS Dual LP's/BD Manifold/Diamond Eye DownPipe/PCV Re-Route/3" IC Pipe/AFE Bladrunner/Suncoast GMAX-6 & 1054/Grid Heater Delete.
06-26-2010, 10:23 AM | #12 | |
Rep 126
Twin scroll is nothing more, and nothing less, than a divided exhaustmanifold connection on to the turbine inletside (see the pics above). There is one compressor wheel, as there's one turbo. There is one turbine wheel, as there's one turbo. And a single turbo cannot be sequential..(in sequence with what?) Edited to add: I think you may have got mixed up with the compound turbo setup found on perfomance diesels, where one turbo actually "blows through" another, in order to achieve the boost levels required by these engines (35-45+psi) . Last edited by Future M1 owner; 06-26-2010 at 10:46 AM.. |
06-26-2010, 11:59 AM | #13 | |
Rep 13
I do come from a Performance Background, it's what I do all Day every Day. ...and Yes, Twin Scroll Technology is now being Used on Diesels, like the New Scorpion Motor in the Fords...Here's how it Works: The 6.7L uses a Garrett single sequential turbo (SST) with variable geometry, a dual-scroll exhaust housing, and an externally actuated wastegate. This turbo has a pair of compressor wheels that are coupled together on a single shaft driven by the turbine wheel. The design is said to dramatically increase the compressor map's range and functions like a sequential twin-turbo system. The boost pressure will be around 30 psi, the turbine shaft speed will see up to 130,000 rpm, and the whole system was designed to function as an exhaust brake. The compressed air will be cooled by an air-to-water intercooler-another first in this segment.
06-26-2010, 01:06 PM | #14 |
45
Rep 1,161
...and bringing things back down to earth...that's not what BMW is using on the N55. It's just one turbo, with one exhaust and one intake impeller running in combination on one shaft.
Richard
06-26-2010, 01:16 PM | #15 |
Rep 1,334
A single doesn't necessarily mean cheaper. Perhaps if it's catless. But it's easy to use, say, a 200 cell HJS cat and propel the DP to 800+ prices.
X3 M40i G01, M235i F22, 335 F30 MSport, 135 DCT, 335 E92, Audi A3
06-26-2010, 01:28 PM | #16 | |
Rep 126
06-26-2010, 01:47 PM | #17 |
Rep 1,334
+1
06-26-2010, 02:03 PM | #18 |
Rep 13
The same way your Picture of a Turbo Kit for an Evo X Ties in.
06-26-2010, 08:32 PM | #20 |
Rep 1,001
So back to topic, what I understand and seem to be seeing from the pictures is that there is a single exhaust connection, and two compressor outlets...
So there is one exhaust side wheel, and two compressors on one shaft and somehow segregated in the turbo body. And so the benefit comes from the fact that you have all of the exhaust flowing through a wheel with high rotational inertia, and two smaller wheels with geometry such that the torque required is lower, so inertia is lower - faster spool, better response, at least in theory... Is that close? |
06-27-2010, 12:12 AM | #22 |
Rep 126
Sir, I will make only one additional comment here, not to prolong this tennismatch with you, but only because it's clear from certain posts that there's a need for some insight on the very basic workings of turbos, and this thread is only prolonging the supply of confusion and misinformation.
-You wrote: For a "Twin Scroll" Turbo, there should be 2 Cold Side Air Inlets, 1 Main Hot Air Out (Both Compressor Wheels Combined), and 1 Main Exhaust Out (Both Compressor Wheels Combined). -This is (still) very wrong. I will state again that the term "Twin Scroll" only refers to the divided exhaust inlet to the turbine housing. It has no reference to anything on the compressor side, and whether the turbo has one, two, or 18 compressor wheels. -Yes, even the Twin scroll SST you referenced, has two exhaust inlets on a single turbine, with a single turbine outlet. Twin Scroll to a t, exactly as explained above. Therefore, even this complex, "Twin Scroll", multicompressor, variable vane baby has, drumroll, a single downpipe. Which brings us nicely back to the N55, and, more importantly, to the topic of N55 downpipes. The N55 has one turbo, therefore one turbinewheel, albeit with a divided turbine inlet, hence the twinscroll moniker, and therefore it has one downpipe. Oh, and I almost forgot: It has a very conventional compressorhousing with, rather disappointingly for some, one single compressorwheel. Last edited by Future M1 owner; 06-27-2010 at 12:35 AM.. |
