02-05-2011, 01:34 PM | #1 |
Rep 400
265's on rear w/ Fender Rolling
I am currently running the stock 264's w/ the typical 255 setup in the rear. Traction is still an issue w/ the added HP. I've been trying to find some detail on running 265's, but to be honest this doesn't seem to be a popular option. i would think i need larger wheels over the 264's maybe 9/9.5 wide. In addition i would like to get my fenders rolled.
Is this even a feasible option? I don't want rubbing, and if i were to lower the car would i definitely incur rubbing issues? thanks
Black Sapphire Metallic 135i/Coral Leather Interior/ Gloss Black Grills/20% tint/M door sills/Black 135i badge, smoked LED side marker, Dinan stage II , DINAN Exhaust, performance side skirts, performance shift boot/e-brake, pedals, carbon fiber wrapped interior
02-05-2011, 06:08 PM | #2 | |
442
Rep 1,658
The APEX ARC-8 wheel was developed over a year ago for this very reason. The rear wheel is 18x9.5" et62 (note the high offset to account for the added wheel width). You can easily run a 265/35/18 on this wheel on both stock and lowered cars with zero rubbing. Members are even running 275/35/18 rear tires or even 275/35/18 r-compounds without rubbing issues (unless the car is slammed/lowered excessively low). Here are some photos to show the fitment: Stock 135i with 265/35/18 Nitto NT-05 extreme summer tire Same wheel and car tested with 275/35/18 Nitto NT-01 r-compound Here's a member's car with 275/35/18 Dunlop Direzza sport Z1's Here's a member's car with the 275/35/18 NT-01's And some other wide front/rear setups
02-05-2011, 07:26 PM | #4 |
Rep 676
I use the Apex wheels and am on 275's in front and 255's in back. With camber plates and KWv2's, the car is a traction beast!
Details: Rear 275's: I did have to roll the fenders, and raise my coilovers a bit to get the clearance. With Dunlop Star spec 275's on Apex wheels, they will also rub on the inside BIG TIME. I gad to put 5mm spacers on the back to keep them from rubbing. If I hit a crazy knock-a-tooth-loose dip, I bet they are still rubbing a little on the inside. So... go 265's and save yourself the headache. There's a good chance you might still need to do a fender roll, but you can do a really minor one like I did. Not even noticeable from the outside. Front 255's: Funny enough, these were easier to get fitted. I did have to do a light fender roll. No spacers needed.
135i // M-Sports Package // RR Oil Catch Can // Black Kidneys // iCarbon Hood // Alum Pedals // KW v2 Coilovers // Vorshlag Camber Plates // Hotchkis Sway Bar // Wheel Studs. Best mod ever? Tires. 255's in front, 275's in back.
02-06-2011, 03:05 AM | #5 |
Bashar
389
Rep 1,116
I have 265 star specs on the rears on stock suspension and wheels. I only rub when the car is full of people and junk. Also only on dips in the road and not potholes.
02-06-2011, 12:20 PM | #7 |
Rep 340
I have 265 rear Yoko AD08s on 9.5" APEXs, and there's plenty of clearance. These run a bit wider than Star Specs, but even with an adult in the back seat, there's no rubbing at all in the rear, period. I could go wider, but a 275 width isn't available in this tire. I did no rear fender rolling at all, but I'm also on stock suspension/stock ride height. For me, the front 255 width fitment was the challenge.
02-06-2011, 02:36 PM | #8 | |
442
Rep 1,658
I don't want to hijack this thread, as it's already been covered before. I just wanted to disclose in this thread that you were the only one with this issue, so that others do not think they also need fender rolling and a spacer to make that tire fit on that wheel. The only issue with running 265's on the stock rears besides the rubbing, is that 265's were not meant to be run on 8.5" wheels, so you're pulling the corners of the thread up off the ground, effectively making the tire narrower, and the bulging sidewalls allow for a lot of flex. I would not be surprised to see GPS data show that 255 rears in the same tire compound would turn a faster lap because it is better sized for that wheel.
02-06-2011, 06:55 PM | #9 | |
Rep 676
I did raise the rear up about 1"-1.5" after discovering the rubbing. So, I should have clarified... if you're on coilovers and want to run 275's on Apex's in the rear- it's best to be near or at the stock ride height in the rear.
02-12-2011, 09:47 AM | #10 |
Rep 400
thanks for the info here... are there any other wheel/tire combos that would work well for the 235/265... i dont think i want to go 275 since that seems to be pushing it, especially keeping in mind potential lowering in the future. thanks.
02-14-2011, 05:54 AM | #11 |
Rep 400
nobody has any other 265 tire setup ups on aftermarket rims? i don't mind the Apex's however i would like a little more curvature in the rim. The Apex seem like they are flush.
02-14-2011, 02:05 PM | #12 |
Rep 2,251
i am running 265 tires in the rear with a 19x10 rim:
BMW 135i/6 Speed/Montego Blue/Formula One Ceramic Tint/JB4 G4/AA Sport Intercooler/19 inch Iconz 880Z(19X8.5 & 19X10)/PSS 225/35 & 265/30/E93 M3 front sway bar/TRW front and rear Control Arms/BMS Drop In Filter/Dinan Exhaust/BlackLines/Upgraded \\\M RSFB |
05-10-2016, 04:52 AM | #13 |
Rep 381
I just put 265 rears and it rubs on dips stock suspension no fender roll i have aftermarket wheels 18x9.5 i forgot the offset. Would a fender roll take care of that?
05-14-2016, 08:20 AM | #14 |
1Addict
3202
Rep 7,860
Depends on where you're rubbing.
05-16-2016, 12:55 AM | #15 |
Rep 381
I looked at the fender and seems like it is rubbing at the fender liner in the back? I'm not really sure it also rubs in the front when I hit the dips on the road and have passengers.
2013 BMW X1 * 1973 Clubman GT * 2016 Mazda MX5 * 2000 Honda S2000 2004 BMW 325i Touring * 2009 BMW X5 3.0xdrive |
08-01-2016, 08:20 PM | #18 |
Rep 471
