05-05-2013, 07:26 PM | #1 |
Rep 2,034
Drives: 2017 F80 M3 ZCP BSM 2012 E82 1
Dinan vs. cobb. vs procede...
I know this has been discussed before...but please help a brother decide
obviously price is the biggest thing between dinan and cobb/procede... |
05-05-2013, 07:30 PM | #2 |
Rep 4,744
Cobb.
05-05-2013, 08:23 PM | #4 |
Rep 2,034
05-05-2013, 08:52 PM | #5 | |
Rep 2,409
I've had, Jb4, Procede and Cobb. If you want something easy to install, set and forget type of thing, get a Cobb. If your out to get max hp and be the quickest on the block. Get a Jb4 and a Cobb to do the BMS flash. If you got a older car, and dont like spending money on small things like spark plugs, coil packs or fuel injectors, then stay away from Jb4. If you run a Jb4 on a car thats not well maintained, then you'll have issues and blame it on the Jb4. |
05-05-2013, 09:50 PM | #6 |
Rep 1,158
N54 gets better power from a Cobb (as I've read). N55 gets better power from a JB4 as there is nothing for a 2012+ 135i from Cobb unless it's some early model 2012s can use Cobb but I haven't looked to deep since they released it for the 2011 N55 a couple months back.
But if you want true power from a real tune then go to a professional, well known local tuner. Remember though, it'll void your warranty but he'll be able to make more and better power than JB4/Cobb/Procede can as he can set it to where you want it. |
05-05-2013, 09:57 PM | #7 |
Rep 403
You should throw GIAC in the pot...
From: http://www.e90post.com/forums/showthread.php?t=374508 Karl. |
05-05-2013, 09:59 PM | #8 |
Rep 5,730
Drives: BMW i3 rex
Garage List 2018 I01 i3s | CURRENT [0.00]
2018 G01 X3 | CURRENT [0.00] 2017 I01 i3 | SOLD [0.00] 2017 F48 X1 | SOLD ... [0.00] 2016 I01 i3 | SOLD [0.00] 2017 F22 M240 | SOLD [8.00] 2016 F25 X3 diesel ... [0.00] 2006 E60 550 | SOLD [6.00] 2011 E90 335 | SOLD [8.66] 2012 E82 135 | SOLD [5.50] 2011 E82 1M | SOLD [7.94] 2007 E85 Z4M| SOLD [4.50] 2003 E53 X5 4.6is S ... [9.00] 2008 E92 328 | SOLD [0.00] 2008 E82 135 | SOLD [0.00] 2008 E90 335 | SOLD [0.00] 2003 E46 M3 | SOLD [7.50] 2006 E90 330 | SOLD [10.00] 2003 E46 330ZHP | SOLD [0.00] |
05-05-2013, 10:16 PM | #9 |
Rep 847
Drives: 2011 135i M Sport
I have Cobb for the reason that it is SUPER easy to remove and install. You just plug it in and start to load the map and it saves your stock map to the unit and you can back it up on your computer. You can also hook it up to your computer and upload stage 2 maps or whatever maps are released. Going from stock to Stage 1 is night and day. I now run stage 2 and sometimes Stage 1+ FMIC. While you drive you can also see on the COBB AP live data like boost, intake temp, RPM, etc. It also has a built in shift light lol. Its awesome man, worth the money in my opinion! For the record I seen up to 14-15psi in Stage 1+ and it tapers to about 9-10 at higher RPM, it makes me happy
BMW Performance Kidney Grille, CF Lip Spoiler, CF Diffusser, Blackline LCI Tailights, Magnaflow Full Exhaust, BMS Intake, Jb4 w/ E85, Meth Injection, BMS DP, VRSF 5" Intercooler, CP-E Charge Pipe, KW CS Coilover, M3 Subframe Bushings, VMR VB3 Wheels, Stage 2 Fuel Pump, M3 Control Arms, Dinan Camber Plates, Pure Stage 2.
05-05-2013, 10:47 PM | #11 |
Rep 1,051
The spreadsheet is hopelessly out of date. Cobb released the AccessTuner Race which allows you to hand touch dozens of tables in the ECU. It's really for advanced users, but it could be on that spreadsheet as dozens of feature checkboxes that the other devices don't have.
The logging is excellent as well. You can record something like 18 parameters at like 30hz+ which is reallly good. You can see exactly what is going on, and its built in to the AP device itself. No laptop required, no extra purchases. Load the CSV in whatever to analyze. I wouldn't even think to consider any reflash where you have to take it somewhere or remove your ECU and mail it somewhere.
05-06-2013, 01:01 AM | #12 |
Rep 2,034
I should add that I have an N55 and have been waiting since I bought the car last May (2012) for Cobb to release an AP for my DME version...cobb was always my first choice and I even cleared it with my dealer who said they would continue to work on it in warranty regardless of the tune.
05-06-2013, 02:39 AM | #14 |
Rep 2,034
05-06-2013, 08:44 AM | #15 | |
Rep 268
Twhill....what dealer are you using? I bet some other local guys would like to know which dealer is mod friendly! My vote is Cobb and a ProTune from BrenTuning....you'll be very happy! |
05-06-2013, 06:04 PM | #17 |
Rep 2,034
pretty unanimous cobb approval haha
05-08-2013, 03:47 PM | #18 |
Rep 2,034
has anyone done dinan stage 3 with oil cooler?
05-08-2013, 04:21 PM | #19 |
Rep 532
Love my cobb, i cant run the 93 map yet because my coils seem to fail.. but even the 91 stage 2+ map is awesome and i love being able to Datalog and check codes so easily... also its super easy to uninstall for a dealer visit.. eventually ill get a pro-tune... jb4 just doesnt compete with these things imo
05-08-2013, 05:16 PM | #21 |
Rep 153
I had Cobb on my evoX, now I have Cobb on my 135. OTS maps are good but I can't wait to get a protune with this car as I did my X. Easy to use, great customer service, and the monitoring aspect is a plus as well.
05-08-2013, 08:23 PM | #22 |
Rep 380
Drives: 2012 135i
N55 Stage 3 here with oil cooler/FMIC with no other mods car made 311-317hp 374-379 ft. lbs torque on a dynojet dyno. It actually made less power with the BMS intake so I took it off.
The car is obviously quicker than stock, but I think the the advertised hp numbers from Dinan are way over stated. Torque seems to be as advertised though. Car pulls like a demon in every gear as long as your above 2k. As for drivability it is spot on. Zero flat spots, zero issues with limp mode, very consistent on the track and street. I wish it was cheaper, but I'd do it again if I had the chance. |
