02-18-2016, 09:19 PM | #1 |
Rep 541
Drives: 2008 135i AT Monaco Blue
Australian Shockworks coilovers (Ohlins alternative)
Hi all
I've been looking into quality coilover options for my 135i and recently stumbled upon Shockworks, which is a Melbourne company. They have been making custom valved dampers for various makes and models for some time now and from everything I've read they come very highly regarded. They are custom valved for each car and height, compression & rebound adjustable (10-12 increments) from what I've read. Many say they are superior to Ohlins and are cheaper (I've seen AUD$2k prices), more comfortable, can be rebuilt locally etc. I've confirmed that Shockworks have made dampers for the 1M but not 135i/335i to my knowledge. I understand 1M dampers cannot be used on 135i/335i cars. For those in the know: - what are the differences between the dampers? - can they be made to fit with replacement arms etc? - how different are the damper & spring rates between the 1M & 135i? If the 1M dampers aren't feasible, my backup plan is to push for development of some coilovers specifically for the 135i/335i platform. Would anyone be interested in a locally developed & custom valved kit on par with Ohlins?
02-18-2016, 09:42 PM | #2 |
Rep 1,140
Drives: N54 135i 6MT
I'll be in the coilover market shortly, do you have any links or reviews you could share with us?
Have you considered KW V2/V3 when they have their factory annual discount sale? Massive savings can be made! |
02-18-2016, 09:49 PM | #3 |
Rep 299
I had a set of Shockworks coilovers in my S15 and they were amazing (extremely smooth and comfortable yet very confidence inspiring on our aussie roads). I would have thought 1M suspension would be interchangeable with a 135i, but if not surely they can develop a set for the E82/E92 135i/335i platform?
A friend of mine used his car as the development car as they did not produce a set of dampers for his particular vehicle at that point in time. I have had coilovers in my 135i previously that were designed for a 3 series, springs rates were probably a bit off but I didn't notice anything drastic during normal driving. |
02-19-2016, 12:54 AM | #6 |
Rep 224
thinking of getting coils too myself and if this company develops a 1 series set im interested to hear the review
also looking at ST coil overs tad cheaper and built by KW also aparently
e84 x1 2012 Sdrive2.0d sold was a fun car in stick
02-19-2016, 03:26 AM | #7 | ||||
Rep 541
If you google Shockworks it comes up with a fair few forum posts and user reviews. I'm yet to read anything bad about them. Here are a few threads: http://www.hachiroku.com.au/forums/s...uspension-Kits http://forum.liberty.asn.au/viewtopic.php?f=19&t=26090 http://www.fordxr6turbo.com/forum/to...ressions-pics/ http://www.fordforums.com.au/forumdisplay.php?f=360 Quote:
I'll keep you in the loop on what Shockworks say about developing a kit for our cars.
02-19-2016, 11:44 AM | #9 |
Rep 319
Drives: BSM e82 135i
Just fyi
MCA suspension do 1 series coilovers now They arent listed on their website afaik but you can email them Far Far Far Superior |
02-19-2016, 12:33 PM | #10 |
Rep 2,186
No the front is different
The hole for the shock in the knuckle is bigger I personally would change the rear control arm and not use those brackets as they will shorten the shock travel At normal shock length it should be a problem, but it possibly be when lowered |
02-19-2016, 03:19 PM | #11 | |
Rep 541
Last I checked MCA Reds were $2600-2900 depending on options chosen.
02-19-2016, 03:23 PM | #12 | |
Rep 541
It sounds like the 1M rear arms aren't a problem. Marty are you aware of any methods of adjusting the knuckle hole or other ways of making the front compatible?
02-19-2016, 04:18 PM | #13 |
Rep 319
I have run them in another car @ozjustin and found the mcas better all round, plus they have proven track performance which is always a big bonus
The reds start at 2500 but there are blues and x options also which come in a lot cheaper. If you arent taking your car to the track the reds are a bit excessive |
02-19-2016, 05:51 PM | #14 |
Jedi samurai ninja turtle
619
Rep 3,021
Drives: X3 M40i 2018
Interesting option indeed!
What other adjustability do they provide? I.e. Camber plates (ala BC racing), dampening dial for front and rears? |
02-19-2016, 10:57 PM | #15 | |
Rep 541
02-20-2016, 02:28 PM | #16 |
Rep 319
No ive run both in other cars, josh from mca was refusing to make the cheaper options other than golds for 1ers until a couple of months ago
02-20-2016, 03:55 PM | #17 | |
Rep 541
02-20-2016, 05:57 PM | #18 |
Rep 31
That is good news indeed as I have been debating between Ohlins or Bilstein coilovers. The more options that are available the better, based on the above info I am leaning towards MCA as they are developed for each car where the ohlins and bilstein are 3 series units.
02-21-2016, 12:26 AM | #20 | |
Rep 682
If you're tracking your car then don't bother with the MCA Blue/Red - get the Gold with remote reservoirs. |
02-21-2016, 05:12 AM | #21 | |
Rep 6,285
02-21-2016, 05:22 AM | #22 |
Rep 2,186
The shock is larger on the 1m so you can't fit it in the 135i
You could fit a 135 Shock in a 1m with a sleeve but it's bigger for a reason to hold more oil ti help with heat dissipation |
