06-04-2018, 05:29 PM | #1 |
Rep 33
135i to M3 steering rack...
Im stuck the M3 rack has a Electric connection missing and I'm not sure where to order one. I tried real OEM but its not listed as an individual part, I even went as far to remove the neck of the rack to swap them out...
any suggestions please and thank you! |
06-04-2018, 05:37 PM | #2 |
Rep 33
I think I found one, I just need a cap I dont really care if the valve works or not I just want faster steering with power assist..
https://www.ecstuning.com/b-genuine-...r/32106788658/ Last edited by TJ135i; 06-04-2018 at 10:06 PM.. |
06-04-2018, 06:10 PM | #3 |
Rep 672
The electric connection stays unplugged unless you want to get fancy.
The M3 rack has servotronic, which is assisted steering weight at low speeds, heavier at high, etc.. Your steering will be noticeably heavier with the new rack, but I don't mind it. I ran this rack in my E90 and run it in the 135i. Your biggest concern should be making sure the rack is 100% centered when reinstalled. The marks on there mean almost nothing.
ajsmithvmi96.00 |
06-04-2018, 08:25 PM | #4 |
Rep 33
The Steering rack I ordered didn't come with the servotronic Im not sure if that one is correct, I think this one will work better since it comes with hardware
https://www.ecstuning.com/b-genuine-...r/32106788212/ Edit: I ordered the part above there is a 3 day wait plus shipping time so I wanted it processed sooner then later. Im fairly certain this is the part I need for the rack, I wish the M3 rack came with the servotrionc, no races for me this weekend, I was on the fence for Fontana Ca this weekend.. Ill go next month.. How do you center the rack? are there measurements I can take and use or what should I be looking for? Edit: I youtubed how to center a rack it looks simple enough, just go lock to lock and place it in the center? Last edited by TJ135i; 06-04-2018 at 09:05 PM.. |
06-12-2018, 01:04 PM | #5 |
Rep 33
situation update that servo is a bitch to find almost all my parts people have it on back order I think Ill get it on the 21st if I'm lucky I really wish I waited before pulling the stock rack out, just frustrating I hope its worth it.
I got shocks and springs from fortune auto delivered today!! |
06-22-2018, 10:43 PM | #6 |
Rep 33
Soon the servo finally came in today but I can't get the rack to go back home, the steering shaft is too long the steering shaft isn't collapsing to allow room for the rack,,
Is this supposed to collapse or is it a solid piece? any suggestions on how to get the steering shaft shorter? I can move the steering wheel in and out but that moves the entire shaft I can't find where it collapses at,, |
06-26-2018, 09:50 AM | #7 | |
Rep 649
06-26-2018, 11:19 AM | #8 |
Rep 33
I figured it out, that shaft picture above is not collapsible, the part that collapses is in the dash just behind the firewall, it helps if you unlock the steering wheel to wiggle it all the way in.
I got it aligned and Its all good now, I think I need to more the shaft over one tooth to be on center. its just a hair off currently. also I broke the clock spring, so none of the buttons work on the wheel. Be careful to make sure not to over spin the wheel as I did, |
06-26-2018, 12:24 PM | #9 | |
Rep 2,028
If the steering rack was off "1 tooth" then you'd only noticed it in terms of full-lock to full-lock rotation count (after the alignment). Basically, you'd have slightly less steering input to hit full lock in one direction v.s. the other. Take it back to the alignment shop and complain the wheel is off center. They should be locking it in place centered before doing the alignment... |
ajsmithvmi96.00 |
06-26-2018, 04:16 PM | #10 | |
Rep 33
I reused wheel spacers on the front wheels and the front now shakes, I'm going to try and fix that and a few other things before I send it back to the alignment shop. |
07-09-2018, 05:28 PM | #11 |
Rep 33
I took it back to the shop and its fixed now, right on center.
I almost want to say this mod was not worth it. Of course I did it by just guessing on a few things, It didnt help that I had to wait for the servo and I broke the clock spring. I do like the mod the tighter steering is nice. Would I do it again, Maybe... Has anyone hooked up the servo after the fact? Could I hook a 12v switch to the servo on the rack to make the steering lighter by pushing a switch? is that a thing? |
07-10-2018, 07:26 AM | #12 | |
Rep 2,028
As for the servo, do you really feel it's needed? You'll get used to the heavier feel. If you still really want it, there are multi threads out there that you need to read instead of going through it all over again here. It can be done with the right coding. |
01-05-2019, 07:43 AM | #13 |
Rep 119
For those of you that are running the m3 steering rack. Did you guys use the m3 tie rods as well or the 135i tie rods? Im wondering because i got mines installed with the 135i tie rods and the steering seems to have some slight play even after getting the car aligned. Not sure it makes a differece but i used the 1m alignment specs. Scratching my head here trying to figure out whats going on. Possibly incorrect install?
01-07-2019, 07:44 AM | #14 | |
Rep 2,028
M3 and 135i outer tie rods are essentially the same. The only difference is the length of the threads. Some people say that M3 outer tie rods are too long and they can't get toe in spec. |
01-07-2019, 09:16 PM | #15 | |
Rep 649
01-08-2019, 05:49 AM | #16 |
Rep 339
In my case inner M3 tie rods were not usable, couldn't get the toe in spec.
As for your M3 rack, don't use the red ATF fluid. It is a ZF rack, specs say to use green CHF11S fluid. |
01-10-2019, 12:04 AM | #17 |
Professional Hack
96
Rep 379
inner tie rods are not usable, had to swap to the 135i's inners.
Servotronic is not worth it. like bbnk2's said, one of the most straightfoward and beneficial mods you can do. |
