05-18-2014, 09:14 PM | #1 |
Rep 105
X5 wheel on 135i
Hi,
I have a 2008 135i ''M'' package. Recently, I have buy 4 wheel from a X5. I need 4 new tires. So, I don't know what size to buy. I think 225/35/19 for front and 255/30/19 for rear. It a good size? Will be safe on the road? Thanks |
05-19-2014, 08:47 AM | #3 |
Rep 1,023
05-19-2014, 09:03 AM | #4 |
Doc Brown
1176
Rep 2,174
not sure if those wheels will fit, maybe to wide. The tire sizes you picked are probably going to be to narrow for those wheels also.
05-19-2014, 09:43 AM | #5 |
Rep 12,565
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.20] |
225 will be wayyy stretched on a 9"
Offsets surprisingly look fine but the 9 and 10" widths are going to be tough. You'll need major fender work IMO. |
05-19-2014, 10:03 AM | #6 |
Rep 919
The rear will fit although there may be an issue with it hitting the strut. If so, just throw on a 5mm spacer for clearance so you can run a 40 offset. You will need to do fender work.
The front 9'' wheel is going to be pretty damn tough to pull off but you can probably do it if you pull the pins up front to max out the camber and pull the font fenders a good bit. Honestly once you factor in all the modification/troubleshooting and the cost of tires, it really makes me wonder if it's worth all the hassle. |
05-19-2014, 12:11 PM | #8 |
Mech Engr
81
Rep 565
its been done before with roll/pull. looked really good imo
http://www.1addicts.com/forums/showthread.php?t=793230 Last edited by c_ozanich; 05-19-2014 at 12:12 PM.. Reason: added thread link |
05-19-2014, 12:20 PM | #9 | |
Resident Tamed Racing Driver
298
Rep 4,697
05-19-2014, 12:39 PM | #10 | |
1Addict
3233
Rep 7,892
05-19-2014, 02:00 PM | #11 |
Mech Engr
81
Rep 565
haha, idk--I didn't do it, just remembered seeing it. Wheels look good; didn't say functional lol
05-19-2014, 03:10 PM | #12 |
298
Rep 4,697
They look awful...
05-19-2014, 03:53 PM | #14 |
Rep 914
That's really not that bad of a stretch. I have 215/40s on 8.5s and 225/40s on 9.5s, contemplated stepping down to a 215/40 on the rears
05-19-2014, 03:53 PM | #15 | ||
Rep 513
full bolt on 6mt
cobb e30 protune fortune auto coilovers 12.08 119 |
05-19-2014, 05:50 PM | #17 |
1Addict
3233
Rep 7,892
Well, glad it's working for you. I wouldn't run it.
Then again, if you're gonna drive it slammed and stretched, there's other issues to worry about and you certainly won't be going anywhere fast anyways.
05-19-2014, 06:18 PM | #18 | |
Rep 513
full bolt on 6mt
05-19-2014, 07:41 PM | #19 |
Rep 363
Why would you want wheels that make you stretch a 215 or 225 tire on em? Wouldn't you want the most contact area you can get as traction is already an issue with the power these cars make. Let alone like mentioned the wheels weigh 40lbs!! I guess I'll never get it
05-19-2014, 09:03 PM | #20 |
Rep 4,040
Drives: 130i coupé ;)
I recommend chnaging rear hubs/ bearing and rotors to e9x spec as per my thread if you want to have 10mm more clearance for such wild wheels
05-20-2014, 08:55 AM | #21 |
298
Rep 4,697
That's what's known as utterly broken.
Sometimes I wish modern tires weren't so forgiving to idiots.
05-20-2014, 09:33 AM | #22 |
Rep 919
