      03-28-2014, 10:58 AM   #1
128Convertibleguy
Drives: 2010 128 Covertible
Smile 128i mod plan - comments?
I'll try to head off stuff I've already considered. And note that I do not want stiffer springs/lowered car. A balance between ride and handling.
Koni FSD shocks.
Eibach 28mm solid front antiroll bar.
M3 (TRW) front suspension arms.
Rear subframe bushing inserts (I'm not hardcore enough to justify the cost of replacing the bushings, at 32K miles and no track/autocross yet, mine should be good enough, the inserts wil help them last longer, also).
OZ wheels 17X8 - 40, Michelin PSS 225/45 and 245/45. (Considered square, want to correct the speedo error, better ride, I can't see how increasing rear grip is a bad idea). Will the rears fit with a 40 offset? If not I could get 45-47 and add a front spacer if necessary. But I don't like the wheels as much.
Camber recommendations? Plan to go with stock toe, F and R.
      03-28-2014, 11:04 AM   #2
kobeballer96
kobeballer96's Avatar
Drives: 6SPD E82
Looks like your on the right track! Disa stage 3 intake manifold. Best bang for your buck if you end up getting a n52 128i
Black Wrapped Roof, BFG Rivals, Dinan Camber plates, M3 Steering wheel, Matte Black kidney Grills, H&R Sport springs,
Sparco assetto gara,Pagid sport Brakepads,STOPTECH Slotted Rotors,
DISA STG3,EURO BOX
      03-28-2014, 11:07 AM   #3
pj.rodriguez
pj.rodriguez's Avatar
Drives: Alpine White 128i Cabrio
Apprently et40 should fit fine both front and rear. And I think you should look into getting different width rims perhaps if you're going staggered. Although, I would highly recommend going square for better control and less understeer. Our N52's don't have that much power to need to have staggered tires.
Go with the subframe bushing replacement rather than inserts. There are some reviews from inserts that weren't much of a difference.
I've also seen a couple things of people selling their solid swaybars because they were TOO stiff. You may want to go M3 sway bar. I've had a ride in a 128i with an M3 front sway and it made a pretty good difference in the turn. More flat ride. With a 28mm Solid, it may be too much.
2008 128i E88 / Alpine White / Boston Leather Sport / 6AT / M3 Paddle Shifters / Bilstein B8 / H&R Springs / Dinan Fixed Camber Plates / BMW 335i Front Brakes / PIAA Xtreme White 4150K Angel Eyes / Rear Fogs Enabled / Cyba Air Scoops / Euro Airbox / BMW Performance Exhaust / Stubby BMW Antenna
      03-28-2014, 11:17 AM   #4
TheSt|G
Resident Tamed Racing Driver
TheSt|G's Avatar
Koni FSD shocks.
FSDs are known for premature failure and do not carry the lifetime warranty that Yellows do. Get the Yellows instead.
Overkill, get the E93 M3 bar if you feel you need a sway bar.
Inserts are close to the same amount of install work as proper bushing replacement. Seeing as some find them to be not much different, I would just do it right the first time(and did).
Awesome choice on the wheels. I would stick with a square setup like 235 all around. Really helps dial out factory understeer and gives you much better tire life thanks to rotations. 40 in the rear is fine, that's what I'm running.
