02-14-2016, 09:45 PM | #1 |
Rep 320
Driver side HID not working.
I washed my car and some moisture got into the driver side headlight unit. The seal wasn't good. I parked the car and swapped the HID bulb into the passenger side headlight and it worked. When I turn the wheels the adaptive feature works.
My HID bulb, halos, turn signal and adaptive feature is working. The only thing that isn't working is the ignition of the bulb. I suspect the ballast is fried. My question is, can the ballast be dead because of water inside the headlight? I thought that the ballast was sealed separately from the headlight unit. And where do you guys recommend to get the ballast? I verified ebay but I'm not sure if they are oem or imitations. Any input would be appreciated! |
02-15-2016, 11:15 AM | #2 |
Rep 310
What if you swap the working ballast over to the driver's side, is all fine? Can't remember if there's an individual fuse for the L & R headlamps?
2011 BMW 135i M Sport Space Grey - BMS JB4, VRSF 3.5" catless DP, Berk exhaust, BMS intake, ER CP, Eibach Pro-Kit, H&R spacers, black kidneys, Blacklines, LUX angel eyes
2014 BMW X5 xDrive 35d M Sport Mineral White - MPBK w/ F85 rotors & Carbotech pads, ACS Springs/Links, iND reflector deletes, iND black roundels, MP black kidneys, M50D grille inserts 2007 Suzuki GSX-R 750 - too much to list |
02-15-2016, 02:09 PM | #4 |
Rep 310
Even though it's a pain, it'll just help you narrow down where the failure point is.
02-17-2016, 12:07 AM | #5 |
Rep 320
Got my headlight off. Some water dripped out when I took the ballast and ballast assembly off.
First picture shows that my ballast is corroded and shot. Second picture: Do you think I have to change this as well if so what's this part? Does this part short circuit when it gets water? Or is it only the ballast that dies? |
02-17-2016, 12:30 AM | #7 |
Rep 131
Your ballast for sure looks to be screwed. But it looks like your adaptive module has some water damage too and it could be a matter of time. I would completely dry out the housing and your control module, you may get lucky and the water didn't hurt anything.
BMS DCI // Catless DPs // BMS OCC // BMW PE // ER CP/TiAL BOV // VRSF 7" FMIC // JB4 + MHD // SSR GT1 // Alpina TCU flash
02-22-2016, 11:54 AM | #8 |
Rep 310
Agreed on the module, there's definitely some corrosion there. If you have the funds, I'd just replace it while you have it out. As for the ballast, yep...she's toast!
