10-14-2013, 11:39 PM | #1 |
Rep 53
N52 Blueprints
I have spent hours looking for all the data on our stock engines and I have yet to find much. Looking for:
Cylinder head volume cc, valve clearance at TDC, gasket thickness, and piston volume. On this engine I believe that this would be a negative number. Also any other data that might be helpful. I am looking to shave the heads for a higher compression ratio. I know this engine is an interference engine so I will have to adjust timing accordingly. Please forgive me for any ignorance as this is the first time I will be putting this type of work into this type of engine. (Last engine I blueprinted was a 350 Chevy.) I have noticed some on this forum are quick to call someone a fool before offering any sort of insightful input. Please prove me wrong in this regard. Many others seem to have a very high level of knowledge which I am looking for. Thanks again n/a 1erz Matt |
10-15-2013, 01:04 AM | #2 |
Admiral of the Fleet
265
Rep 3,552
See if this helps you out. It was posted on the e90 forum, so if the link doesn't work, I've attached it as well and should have everything I think you could ever want to know about the engine:
http://www.e90post.com/forums/attach...hmentid=659246 |
10-15-2013, 09:14 AM | #3 | |
Rep 45
10-15-2013, 11:09 AM | #4 |
Rep 53
Thanks,
I remember seeing this before. Can't believe I forgot about it. Really cool read. Found some stuff I am not so fond of. (Aluminum bolts that have to be replaced whenever the engine is rebuilt.) Still missing lots of the info I need though. I am sure this info is somewhere. Where is the problem. |
10-15-2013, 04:26 PM | #5 | |
Resident Tamed Racing Driver
298
Rep 4,697
10-15-2013, 05:29 PM | #6 |
Rep 2,239
That's what frustrates me so much. There are engines in the car market that are way inferior than the n52 yet they have 10x the support. n52 is a hidden gem in the rough.
edit: i do recall reading about completely race built n52's that rev'd to 8500 and had 285 rwhp, your best bet would be to find those teams running them and ask if they would give up any secrets.
08 e93 335i MT
10-15-2013, 10:37 PM | #7 | |
Rep 53
10-16-2013, 05:36 AM | #8 | |
Emperor
1614
Rep 2,753
BMW makes exceedingly free flowing heads from the factory. Probably not much to be gained there. Decking the block may prove tricky as well-- Don't forget that the N52 is magnesium protected by aluminum. If you expose that magnesium, you may be able to literally watch your engine rust away. Then again, maybe there's space to do that there. I've never heard of anyone trying, so just voicing a potential pit fall. IMO the N54/N55 is an awful engine compared to the N52.
2005 M3 Coupe, 2004 M3 Wagon, 2001 M5 Sedan, 2008 M5 6MT Sedan, 2012 128i M sport |
10-16-2013, 06:38 AM | #9 |
Слава Украине!
2317
Rep 2,440
10-16-2013, 01:27 PM | #10 | |
Rep 53
I am sure these heads flow a million times better than any old Chevy head but those small gains are exacly what I am looking for. I will for sure agree with you that the more advanced engine is the n52 but the n54 makes more power easier is all I was saying <although this argument has been had too many times and should be mute at this point lol. I have a buddy that has a "built" n54 with 500hp (Chip and Meth injection) and points it out every time I talk to him about the n52. I cant wait to see what woking with the internals will yeild on the n52. Does anyone know of anyone who has done so? |
02-26-2017, 04:43 PM | #11 |
Rep 15
Wow this is a great thread for n52 enthusiasts who are dying to "squeeze" what they can out of it. I use the term "Squeeze" because everything people have done in the past only yields such little gains but something tells me we are all missing something here. Its just a matter of failing and trying again. Now who has the money and balls for all that? huh? If i wasn't dealing with mine as a DD i would venture down that dark and lonesome road and find something for us. Hope someone does down the line before my impulsiveness makes me buy a honda civic as a DD and my 1'er as my tear apart weekend car. lol
