02-20-2018, 01:50 PM | #1 |
Rep 439
Street and Track Build - 519.E82
Hello,
I decided I wanted to try and put my car into some shows/events local to me this year and had to take some new registration photos so i thought i would update here. To make it easier for everyone i will also include where i got everything - 1M/M3 Mirrors wrapped in gloss black (Schmiedmann) - BMW Aerodynamic front bumper paint matched (BMW) - BMW Aerodynamic sideskirts paint matched (BMW) - LCI Blackline tail lights (Schmiedmann) -OMGSplitters front lip with APR 8mm support rods (OMGSplitters and Amazon) - Carbon fiber rear spoiler/lip M4 style (Ebay - dont remember exactly who from) - BMW Performance Exhaust (BMW) - Black wrapped window trim - 20% tint all around - Blackline front grills (BMW) - AFE Intake scoops in green (Amazon) - Powder coated wheels - Blacked out side markers
2008 SGM 128i - 3 Stage IM - 130i Tune - Dinan Camber Plates - BMW PE - Injen Intake - 1M Mirrors - LCI Blacklines - M4 Spoiler - Blacked 263's - Aero Bumper - Aero Side Skirts - OMGSplitter - AFE Intake Scoops
Esteban43674.50 andrey_gta298.00 BAN_M2C4180.00 chadillac20001221.50 snub-nose 2855.50 BimmerAg425.00 desertman1232213.50 Upgrade+129.50 austinaslink177.50 |
02-20-2018, 07:30 PM | #4 |
Rep 8,165
Wrong order of mods.
Suspension first. Then wheels. Then Aero. Doesn't look too bad though except the front splitter thing |
snub-nose 2855.50 |
02-20-2018, 08:31 PM | #5 | |
Rep 439
But i appreciate the feedback
02-22-2018, 07:19 PM | #7 |
Joint Chiefs of Staff
24186
Rep 190,797
Looks great!
519.E82245.00 |
02-26-2018, 02:33 PM | #9 |
Rep 3,234
Rochester here and like taking drives to Toronto in the summer. I don't have fb, is there another outlet to know about the meetups?
04-28-2018, 11:45 AM | #10 |
Rep 439
Update:
Have a rather large update here, been a real busy week.
Summer has now kind of arrived so the summer tires went back on. This time around though I put on my BMS Spacers with a 12mm in the front and a 15mm in the rear Before After That's just the front but rear had similar results. I have all of the DIY Install steps aswell if anyone wants to see those. Next up was a rather large DIY in comparison. I bought a 3 Stage IM from another forum member mad1stgen , got some new seals, and set up a new hard drive to run INPA and all accompanying software to be able to tune it. The install went rather smoothly took a little bit as some connectors were a pain in the ass, but overall on first start up went flawlessly. I think i made 1 or 2 mistakes though while re-routing the power steering reservoir I think the lines are just slightly in the wrong spot so no biggy. The second issue I made was I think i put a cable in a holder a little to early as now the box that attaches to the cowl has to much tension and is about 1 mm to short from connecting back in its holder. Mid Install Lastly, It was tuning time. This was a major deciding factor in doing the 3-Stage IM, was that the tune for it was free (besides a $30 cable). I went with the Bimmerlabs tune/flash that converts you over to a base 130i tune, which does incorporate the DISA valves. I highly recommend Bimmerlabs as its free, they had great support to answer my few questions, and it went over flawlessly. Also shout out to desertman123 , for his build thread informing me of bimmerlabs and helping me reset the adaptations. I originally forgot to do this but did the next day and definitely felt the change in the top end after doing this (previous to resetting the adaptations I only noticed a low end change). Not 100% on what will be next, I saw some ghost codes for the VANOS solenoids im going to look into, but until then here is my current update pic Update
desertman1232213.50 |
04-28-2018, 10:18 PM | #12 |
Rep 439
I notice the attachments aren't working 100% on the second post, so i will reupload them, in the same order on a later post
04-29-2018, 11:35 AM | #13 |
E82 Mudflap Ambassador
2214
Rep 2,219
Drives: '08 128i
This is like ideal 1 series spec that isn't the 1M look
I also saw a few VANOS codes a little after tuning. Not sure if that's 100% coincidental for both of us but it's an observation. I cleared the code and it came back like a week later so I just replaced both solenoids (I've already cleaned them multiple times). Figured at 115k they were due.
Parents' 2014 528i - Mineral White/Ivory White - fully loaded Instagram @Andreys_128i and @Honda.Bito |
519.E82245.00 |
04-29-2018, 11:38 AM | #14 |
Rep 439
Thanks! now its tough deciding on if i want to work on the ideal suspension, or engine. Having done the 3-Stage IM, i'm now considering doing MILVs and Headers at some point.
But also need to finish the exterior with a new rear bumper to get a diffuser.
05-10-2018, 03:10 PM | #16 |
Rep 439
Update:
Decided I wanted to try a bit of change. I decided after much debate to paint my calipers red, and soon will be doing my intake scoops as well. For using a rattle can vs powder coating i'm pretty happy with the results, turned out pretty good.
I also installed a hidden plate that you can see (slightly) folded down underneath my lip.
05-10-2018, 05:40 PM | #17 | |
Rep 439
05-11-2018, 11:17 AM | #19 |
2214
Rep 2,219
Drives: '08 128i
Barely, it was a hair smoother but not a massive difference. Putting 6 new coil packs made a way bigger difference.
519.E82245.00 |
05-13-2018, 02:29 PM | #21 |
Rep 439
Yes install was plug and play, very easy. They are heated, and i recommend buying them from schmiedmann, seemed to be the cheapest and easiest
