09-25-2013, 02:40 PM | #1 |
Rep 575
Does Your Oil Filter Housing Look Like This?
Is this normal? I'm looking at pictures of N54/N55 engines online and all of them look smooth. I don't know what the white spots are or what caused that. I don't know if it's corrosion or not. I find it hard to believe that it's corrosion because the car has lived in AZ all its life. Thanks for your time and input.
2011 135i 6MT | Alpine White | Terracotta Boston Leather | M-Sport | BMW Performance Exhaust Resonator Delete | Active Autowerke Signature Exhaust | BMW Performance Suspension | Blackline LCI Taillights | BMW Performance CF Spoiler | CF Rear Diffuser | PPK | E92 M3 FSB | Matte Black Kidney Grilles | VMR V710 Jet Anthracite | Michelin PSS | BMW SS Pedals
09-25-2013, 03:44 PM | #2 |
Rep 6,478
Just looks like accumulated crud and debris, I wouldn’t stress. Absolutely does not look like rust to me.
F30 N55 XDrive EBII |
09-25-2013, 04:38 PM | #3 | |
Rep 575
I haven't lived in states that get snow but it looks like corrosion from salt? I'm not sure - it's a total guess. The weird part is that this car has lived in Sunny AZ all its life... Thanks for the response man!
09-26-2013, 08:03 AM | #9 |
Rep 928
This.
Its generally a mix of all kinds of things, soap from a wash lightly spraying over the aluminum, regular contaminants in the air can even effect the appearance of unfinished aluminum. Where aluminum that is polished and ground doesn't get this, because there aren't imperfections in the surface finish allowing foreign molecules to attach to and spread (at least not as severely given a time duration). It is a cast, so there are microscopic pits that can't be seen to the naked eye that allow this to happen, and make these little white marks. Nothing is going to happen, and is perfectly normal. Nothing to worry about. Cheers! |
09-26-2013, 09:49 AM | #11 |
Rep 385
Technically you are looking at corrosion. Aluminum is highly reactive. The good thing is that it readily reacts with oxygen creating Aluminum Oxide. Aluminum Oxide is very strong and the very thin outside layer protects the inside aluminum. What you're looking at could have been something breaking down the outer corrosion layer and it reforming afterwards. Corrosion is good for aluminum, so you should be fine. Just keep mercury away from it.
09-26-2013, 10:17 AM | #12 |
Rep 575
Thanks for the input and suggestions guys!!! I really appreciate it and all your responses made me feel very relived.
09-26-2013, 04:30 PM | #13 |
Rep 1,668
you could give it a good scrubbing wth steel wool or something and then give it a clear coat of paint. This will prevent any further corrosion. pain in the butt to do though has to be really clean and free of blemishes. too time consuming for me but for those who are OCD this will work
Enjoying an E89 Z4, F30 320i and Fiat Abarth //
E85 Z4 (sold), E82 128i (sold), Fiat Pop 500 (sold) |
09-26-2013, 04:51 PM | #14 |
bimmerphile, technogeek
998
Rep 3,784
Drives: 2012 E82 6MT Sport
You shouldn't use steel wool on the aluminum because it causes galvanic corrosion, I believe.
09-27-2013, 08:48 AM | #15 |
Rep 1,668
yeah that is a good point. Maybe a copper brush or some other no reactive metal to scrub the casing. Thanks for the correction.
09-27-2013, 09:01 AM | #16 |
Rep 928
Aluminum wheel cleaner will lift it. Use a softer brush, like nylon, and wear gloves. If you can't locate wheel cleaner, soaking it with concentrate simple green and a soft rinse should lift it as well.
I wouldn't use any type of metal brush, though, because you can still score the surface of the aluminum. Nylon, or a horse hair brush would even work. |
09-27-2013, 11:46 AM | #17 | |
Rep 1,668
09-27-2013, 12:54 PM | #18 |
998
Rep 3,784
Maybe a medium-bristle toothbrush with a small head, like a kid's toothbrush... Or one of those small, round-headed electric toothbrushes.
09-27-2013, 10:07 PM | #19 | |
Rep 130
09-30-2013, 07:57 AM | #20 | ||
Rep 928
I have used simple green. So have others. If you are unsure of an aluminum protectant, Sharkhide is used a lot with marine and aircraft aluminum, along with guys rebuilding aluminum heads. |
