      08-05-2011, 06:49 PM   #1
mrrosie
Drives: 2008 - BMW 135i ~SGM ~
OZ Catless downpipe questions
Hi all, just a newbie to the forums but a \"veteran\" 2008 135I owner with admittedly very limited knowledge in engines etc.
I have been trying to search on my app (as that is the main way I view the forum - I don\'t access a pc much) and haven\'t had any luck with finding answers the following q\'s. So apologies if these have already been asked...
1. Are catless dps legal in Australia?
2. Are the dps worth getting and why? Sound? Power? Better for the engine?
3. Do you know of any places in Sydney where they can be purchased and professionally installed?
Thanks!!
2008 - BMW 135i ~ SGM ~ Terra Interior ~ Black Grilles ~ Satin Black Wheels ~ BMW Performance Brakes ~ Afe Intake Scoops ~ BMS Drop-in filter ~ JB4
Have,but still to install: 12mm Wheel Spacers front and back...
      08-05-2011, 07:23 PM   #2
Alpha Trion
Alpha Trion's Avatar
Drives: 135 Convertible
- Nothing catless is legal in Aust. But in my opinion our cars have 3 cats, i'm sure removing the one of the DP wont hurt as long as the cops see that you have one on each of the 2 pipes.
-Sound, power and freedom for your turbo's. Definitely a mod worth getting!
- Purchased is a NO.. you will have to get them from the USA. Installed YES any exhaust centre should be able to do it, although one that has previous experience is strongly recommended!!
Hope that helps
      08-05-2011, 08:33 PM   #3
Zuzu
Zuzu's Avatar
Drives: M2C HS 6MT
Ahhhh. The N54 has 4 cats mate. Two off the turbos and two on the midpipes. I have removed the two midpipe cats and the resonator.
      08-05-2011, 10:00 PM   #4
mrrosie
Thanks for the reply!!
Looks like I'll be doing the dps as my next mod.
      08-05-2011, 11:43 PM   #5
mrrosie
Just noticed that AR have the DPs in both catless and with cats now for a little bit extra....
In your opinion (once again with me not being too tech minded) shall I fork out for the with cat option?
Is there much difference between them?
      08-05-2011, 11:58 PM   #6
Zuzu
Zuzu's Avatar
Drives: M2C HS 6MT
If you going to all the trouble to purchase and install DP's, you really can't go pass catless... Its the only way to go with Dp's to get maximum performance gains.
      08-05-2011, 11:59 PM   #7
JB4-335
Drives: E92 BSM & E70 AW
Go catless if you have a tune. Catless=More power. You will need a tune to delete the catalytic converter codes. I think the catted are a waste of money.
      08-06-2011, 12:40 AM   #8
Orlin
Orlin's Avatar
Drives: F30 335i
If you are going to go catted ar dps then save the $1200 and leave what you got because your gains will be very small and you wont even notice them when driving.
      08-06-2011, 01:00 AM   #9
mrrosie
Thanks again guys, your feedback helped a lot!
      08-06-2011, 03:42 AM   #10
MrBlonde
MrBlonde's Avatar
Drives: Audi TTRS, M Coupe, 1299
That's it.
Check out the 1Addicts Drag Racing Standings and Drag Racing 101.
      08-07-2011, 08:58 PM   #11
Alpha Trion
Oh yeah my fumble Zuzu thanks for pointing that out
I will be hopefully installing DP's soon.. mine are catless.. but the midpipes will have cats on. They will 100cpi so they almost AREN'T cats if you know what im saying
      09-30-2018, 09:53 PM   #12
NinjaDog
NinjaDog's Avatar
Drives: BMW 135i
Has anyone been caught by cops/epa with Catless downpipes (N54)? If I leave the midpipe it's still technically catted right?
      11-22-2018, 02:13 AM   #13
xQx
if you have to do an EPA test, you'll fail.
if you get a thorough roadside inspection, you'll pass because only enthusiasts and mechanics know there should be primary and secondary cats on a N54. ... anyone else is going to see the secondary cats and say "yup, that's catted.".
also, because of the secondary cats, a car with carless downpipes doesn't smell like a car with no cats.
(a straight piped exhaust has a faint fireworks smell)
      11-22-2018, 11:39 PM   #14
dainese
Drives: BMW 135i
I was told by a workshop that there is a difference but not a huge one. think 5kw or something, give or take, pending conditions etc.
      11-23-2018, 01:17 AM   #15
xQx
If you run a stock tune, that might be correct; but if you're looking to up your PSI (ie. run MHD Stage 2), the exhaust and intake restrictions are important.
The stock intercooler is restrictive, but nothing like the restriction caused by your primary cats.
If you want to go cheap, do it DIY. Take your stock downpipes off and bash the the primary cats out with a crowbar, then re-install them. It'll give you 90% of the benefit of VRSF downpipes for the cost of a couple of gaskets and a few hours of your time (maybe 10).
But the general consensus among the n54 tuning community is that your downpipes should be the first mod you make. Intercooler is your second.
(after the parts that are prone to fail - eg. coils and your chargepipe)
      11-25-2018, 06:06 PM   #16
dainese
Drives: BMW 135i
Yeah, I take your point. Makes sense too.
I am a walking contradiction as I care about emissions but also love cars too!
See how I go
