      05-26-2010, 05:32 AM   #1
arrutled
arrutled's Avatar
103
Drives: Olsa
Holy Rolling 1 Series Batman!
wahoo!
AW 135i w/ blackette, performance short shift kit, BMW alarm, Performance rotors, APEX ARC-8 wheels, Direzza Star Spec 235/275, Dinan stage 3 suspension, M3 wishbones/tension rods/front sway/rear subframe bushings and thats all folks!
      05-26-2010, 07:31 AM   #2
Irishace
ElevenPointFive
Irishace's Avatar
Drives: E90 335
Nice
2008 E90 335xi - N54 Daily Driver
MHD Stage 2+ ~ CPE DPs ~ BMS Intake ~ AMS FMIC
      05-26-2010, 07:41 AM   #3
BMW86
Drives: RS3 Sedan / Macan S
woah!
      05-26-2010, 07:48 AM   #4
frosh
aw e92 335xi
frosh's Avatar
Greece
72
Drives: aw e92 335xi
swayy barrsss!
stage 3 dinan | v710 | blk grill | mtech front | hamann lip | i-drive | red int | side markers| afe intake | kw v1 | yellow fogs
08’ E92 AW 335xi – Auto
      05-26-2010, 10:04 AM   #5
Garduna
Garduna's Avatar
Drives: Sedona 1er|Yellow S3|NardoTTRS
lol awesome
      05-26-2010, 10:08 AM   #6
Itanius
Drives: Silver
Nice! It definitely looks like the inside tires are lifting off the pavement a little.
2008 AW 135i (sold)
      05-26-2010, 10:59 AM   #7
larryn
Enhanced a bit to show detail (including tire)...
      05-26-2010, 11:02 AM   #8
larryn
Originally Posted by frosh View Post
swayy barrsss!
Andy has M3 sway bars, M3 front bits (tension and LCA), and rear subframe bushings.
My best guess is that there's a little oversteer or drifting going on there, exaggerating the lean, and the orig pic was a bit off level.
Here's orig:
      05-26-2010, 12:15 PM   #9
arrutled
arrutled's Avatar
103
Drives: Olsa
AWESOME!!!!!!
Love this setup!
      05-26-2010, 03:01 PM   #10
KingOfJericho
KingOfJericho's Avatar
Drives: Yes
2010 135i Coupe  [5.26]
Horizon is off which exaggerates the roll.
The views and opinions expressed in this post are those of the author and do not necessarily reflect the official policy or position of Bimmerpost.
2018 Jeep Grand Cherokee High Altitude Hemi | 2010 S4 Sold | 2010 BMW 135i Retired | 2006 Lotus Exige Sold
      05-26-2010, 03:05 PM   #11
Bimmer-Bob
Bimmer-Bob's Avatar
Drives: 2010 128i
Attachment 390362
Good point, but his inside tires are def. coming off the ground regardless.
____________________________
      05-26-2010, 03:13 PM   #12
KingOfJericho
Drives: Yes
It's a heavy, narrow car. I am not surprised that the wheels come up. You have to lower the center of gravity and stiffen up the corners to reduce this type of body roll.
      05-26-2010, 04:14 PM   #13
arrutled
arrutled's Avatar
103
Drives: Olsa
Who wants that when you can get awesome shots like this!!!
      05-26-2010, 06:11 PM   #14
larryn
Attachment 390362
Right, I fixed that in my edit of the orig, along with a few other tweaks.
Look at the enhanced version of the exact same pic. The inside edge is still on the ground, and it's because of the added negative camber that the outside is not touching.
      05-26-2010, 08:29 PM   #15
arrutled
arrutled's Avatar
103
Drives: Olsa
2.5 degrees camber to be exact.
      05-26-2010, 09:26 PM   #16
Sidh135i
BMW Technician
Sidh135i's Avatar
nice shot!
      05-26-2010, 10:08 PM   #17
BrokenVert
Resident Kerbalnaut
BrokenVert's Avatar
schweet!
      05-26-2010, 10:41 PM   #18
lib
lib's Avatar
141
Drives: <This space for rent>
Good point... Lets fix that.
      05-26-2010, 11:25 PM   #19
bimmerboy
bimmerboy's Avatar
23
mmm those are some wide tires
--2009 BSM 135i--
-Manual, Sport Package, BMW Assist
      05-27-2010, 07:51 AM   #20
larryn
Yep, they sure are!
Same car, with me driving at same corner, mid-drift (2nd pic shows car position fraction of a second earlier):
      05-27-2010, 08:50 AM   #21
bimmerboy
bimmerboy's Avatar
23
are you on the stock suspension?
how much grip do you have now compared to the runflats? Has the overall balance changed or are you still understeering with the staggered setup?
--2009 BSM 135i--
      05-27-2010, 09:16 AM   #22
larryn
Andy has M3 sway bars, M3 front bits (tension and LCA), and M3 rear subframe bushings.
Along with the M3 bits, Andy's car has -2.5 camber up front via Vorschlag plates, Eibach springs, and 255F/275R Star Specs.
You cannot really compare this car (or mine, which is very similarly set up) to a stock suspended 135i with runflats. They are two very different animals. There's heaps more grip and gobs of better - and more predictable - turn in. Both Andy (arrutled) and I were driving the car at about 60mph in these pics, around a fairly tight sweeper. VERY fun!
