      12-11-2011, 01:02 PM   #1
Flipwit
Drives: 2016 M235i
where to ground alpine HIDs on an n55?
Hi everyone,
So i went with an alpine HID kit, and i found the positive hookup no problem, but i can't seem to find a grounding hookup like the videos. i know those are n54 engines and i have an n55, so where have you all grounded your kits in the engine bay? Thanks!
      12-12-2011, 09:59 AM   #2
Joaco135
Joaco135's Avatar
Drives: 2020 M2C LBB
I installed mine yesterday and like you was looking for the ground, works like a champ without it. However if you look at this install video (
for the V3 it doesn’t show a ground connection either. It must be the V3 that doesn't required an external ground or its using the vehicle ground via the lights connector.
      12-12-2011, 12:50 PM   #3
1speedbike
1speedbike's Avatar
732
Drives: 2022 X4 M40i, 2008 135i
The V3 kit doesn't need a ground. The V2 kit attaches to a negative terminal which in the N54 is underneath there the tube for the windshield washer fluid is.. But I don't know if that's also there on the N55. It should also work if you just attach it to any screw in the engine bay that's connected to the metal body of the car (unpainted metal).
2022 X4 M40i - 2008 135i - 2015 F700GS
On Order - 2024 i4 M50
Scruffy's gonna die the way he lived... Mmhm.
      12-12-2011, 03:59 PM   #4
Flipwit
Drives: 2016 M235i
That's what i was hoping for. I would feel better having it grounded as it comes with a grounding lead. Thanks!
