10-21-2014, 05:52 PM | #1 |
Rep 201
Windshield and headlight washers not working after water pump replacement...
As title states, ever since I had my water pump replaced, the headlight washers and windshield washers have no longer functioned. When I press to activate them, i hear the pump trying but no fluid comes out despite the the washer fluid is topped off, just a few bubbles out of one windshield nozzle.
Not sure if theres a clog somewhere in the system and since I'm not familiar with it I'm not certain where to even begin trying to pull hoses apart to find where the block may be. If anyone can give me feed back or suggestions that may be familiar with this issue it'd be much appreciated. |
10-21-2014, 07:30 PM | #2 |
Rep 1,293
Was it working before the water pump replacement? And did the dealer top off the reservoir and you just noticed it wasn't working? I made the mistake of letting my reservoir run dry and it clogged. Thankfully it was replaced under warranty. There is absolutely no reason for the dealer to remove or even touch the windshield washer system when replacing the water pump. At a minimum, make sure they didn't put radiator fluid in the reservoir by mistake. Believe it or not, crazier things have happened.
10-21-2014, 07:53 PM | #3 | |
Rep 201
10-21-2014, 09:36 PM | #5 | |
Rep 201
10-21-2014, 10:18 PM | #6 |
Rep 64
Drives: 08 E88 135i
From related research I have been doing about the washer system (my nozzles start to dribble due to pressure in the system when the washer fluid heats up. Tried to see if there was a vent to find to unclog), the headlight pump is different than the nozzle pumps, but both are attached to the tank.
I would make sure that the headlight ones are actually not firing at all, since if they are, then that at least points you in a direction. The tank should be on the passenger side under the front wheel liner. |
10-21-2014, 11:51 PM | #7 | |
Rep 201
10-22-2014, 09:44 AM | #8 |
Rep 469
Drives: 2008 BMW 135i 6MT
My brother had this issue on his 135, I believe it ended up being material buildup on the filter inside the tank that needed to be cleaned out. Once the little plastic filter was clean it worked fine
10-22-2014, 09:51 AM | #9 |
Rep 201
10-22-2014, 12:27 PM | #10 |
Rep 469
10-22-2014, 03:11 PM | #11 |
Rep 201
02-22-2015, 10:30 AM | #12 |
Rep 131
I recently started have this same exact problem. My tank is full, but neither my headlight or windshield washers are spraying. It is just a dribble from the hood nozzles.
Did you ever figure out your issue? I hope it is just a little clog in the system. Aaron |
