03-24-2014, 07:51 PM | #1 |
Joint Chiefs of Staff
4916
Rep 115,980
New CPE Cast Downpipes - Robot Welded - Fits Non-XI and XI - ON SALE!!!
- 2007-2010 BMW 335i / 335xi - 2008-2010 BMW 135i / 135 xi - 2011+ N54 335IS Available in CATTED and Catless Order Link - On Sale for 599.00 http://www.n54tuning.com/index.php?_...&productId=159 Eliminating restrictions in the exhaust system is key to increasing efficiency and power. Back pressure causes delayed turbocharger response and is a bottleneck. FEATURES CAM/CAD Engineering Full 304 Stainless construction Cast bellmouths for smooth transitions Mandrel bent tubing Laser cut flanges TIG welded Available with High Flow Catalytic converters Optional Wideband O2 bungs available Made in the USA Lifetime Warranty cp-e™ cast stainless downpipes have been designed specifically for the n54 motors to reduce back pressure and optimize exhaust flow. +12whp +10wtq CAD designed castings channel the gas from the twin turbos into mandrel bent tubing – as a result there are no harsh bends or transitions restricting flow. Made completely of high grade 304 Stainless steel, the system is strong and durable. The ultra-precise fitment of the downpipes is the result of painstaking attention to detail and the utilization state-of-the-art manufacturing equipment. cp-e™ utilizes the latest in 3-D digitizing and reverse-engineering tools, and also take advantage of robotic cutting and welding systems to reduce the influence of human error. These tools ensure that each example is true to the original prototypes, which guarantees ideal fitment each and every time. The downpipes may be installed without any permanent modifications, and are available with or without high-flow catalytic converters and additional wideband oxygen sensor bungs. Last edited by Mike@N54Tuning.com; 04-11-2014 at 08:43 AM.. |
05-07-2014, 07:17 PM | #2 |
4916
Rep 115,980
