11-30-2016, 05:12 PM | #1 |
Rep 12
Carbon Fiber Interior Trim
wanted to replace the wooden trim and didn't want to spend the money for silver or carbon fiber so I decided to buy some vinyl wrap from a local wholesaler and attempt it on my own. Here's how it turned out! Cost less than $100 including buying tools and still have enough left over to do my mirrors and then some.
11-30-2016, 06:26 PM | #3 |
Rep 12
If you use a little trim removal tool or wedge you can try it off, it's just held in my clips. The corner of the piece under the edge of the iDrive wheel is a little bit harder to get out but can still be done by wiggling it out. Also you could pry the iDrive wheel part of the console up slightly to give you better access.
Edit: Or are you talking about the carbon strip on the knob itself? |
11-30-2016, 09:08 PM | #5 |
Rep 12
I just took the know out of the car, wrapped over the trim, cut the vinyl so and leave a couple millimeters extra and heat and mold it into the crevice. Then I just cut and cleaned up but I'm not sure how to take that piece off
12-03-2016, 07:27 PM | #6 |
Rep 12
Drives: 2012 BMW 128i
Nice job!!
02-28-2017, 11:45 AM | #8 |
Rep 310
I need to do the same to get rid of the woodgrain...which looks cheap IMO.
2011 BMW 135i M Sport Space Grey - BMS JB4, VRSF 3.5" catless DP, Berk exhaust, BMS intake, ER CP, Eibach Pro-Kit, H&R spacers, black kidneys, Blacklines, LUX angel eyes
2014 BMW X5 xDrive 35d M Sport Mineral White - MPBK w/ F85 rotors & Carbotech pads, ACS Springs/Links, iND reflector deletes, iND black roundels, MP black kidneys, M50D grille inserts 2007 Suzuki GSX-R 750 - too much to list |
