01-16-2015, 07:17 AM | #1 |
Rep 184
Does anyone know if the 135i (08 to 2012) BMW performance brake calipers with fit the 335i coupes "any help Will be greatly appreciated.
01-16-2015, 08:25 AM | #2 |
Rep 12,565
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.20] |
Doubt it and even if they did it'd be a downgrade in performance
01-16-2015, 09:34 AM | #4 |
H O O N
86
Rep 694
The calipers should drop right in since the knuckles of a 135i and 335i are the same. This will require use of the 135i discs as well. IIRC the rears are an issue since the parking brakes are not the same, you'd have to make an bracket to adapt the 135i caliper to the 335i rear disc. At that point braking balance might be an issue.
Decrease in performance since the BMW performance 135i rotors are smaller and thinner than the stock 335i ones. Besides the aesthetic value, you'd be better served getting rotors and pads meant for a 335i.
U WOT M8? |
