      10-23-2013, 01:45 PM   #1
One35iMT
Drives: 2009 135i M Package 6M/T
Comfort Access Problem...
Here is my story,
My Comfort Access doesn't work when key fob is in the pocket, but it works fine when it's out of it.
I took it to the dealer since i purchased the "extended warranty".
They just simply replaced my key battery and quote that "It's Working Fine" but BS that. It never get fixed and they charged me $10 for battery replaced.
Next day i went to dealer again, now they told me it's the vehicle's battery that caused the problem and quote me $455 to replace the battery. I told them to I'll not replace the battery because i never had any issue with battery not even a low battery indicator displayed. They said they to charged me $150 for diagnostic fee. Why didn't they told me in a first place that it was the vehicle's battery problem? I'm fear that what if i replace the vehicle's battery and it doesn't solve the problem again, then they will point out the different problem.
Does any one has the same CA issue? how do you solve the problem? other than replace the battery.
      10-23-2013, 01:50 PM   #2
pj.rodriguez
pj.rodriguez's Avatar
Drives: Alpine White 128i Cabrio
Sometimes when the keys are in your pocket next to a cellphone or some electronic device, the CA will be funky. This happens to me sometimes. Also, what are the issues that you have. Is it when you open the door? Open the trunk? Lock the doors?
      10-23-2013, 05:21 PM   #3
CAVU
CAVU's Avatar
Drives: '16 F87 M2
My last three non-BMW cars all had 'comfort access' functionality, and all of them worked 400% better than my 135is, which is amazingly finicky when locking the car or releasing the trunk lid. Opening the car is OK. Not sure why it is so bad. I occasionally get the "no key detected" message in the car… it happened again today as a matter of fact.
F87 '16 M2 ... Mineral Grey, 6MT, Exec, MPE
Gone: E82 '13 135is 475/586 ... Mineral Grey / Oyster, DCT, Premium, Tech, HK, Michelin PSS, BMW Performance Suspension
      10-23-2013, 05:25 PM   #4
b1aze
Just one more taste...
b1aze's Avatar
Drives: 2013 128i 6MT MSport
Do some testing for me.
Does it do the same thing on both doors and the trunk?
Does it repeatably not unlock the car if it's in your pocket?
These will help diagnose if its a handle, module or key problem.
      10-23-2013, 06:31 PM   #5
owen2001
owen2001's Avatar
Drives: 2013 135is
That's bizarre. I have the IS and haven't had a single issue w/ my key or the comfort access functionality. Not sure why yours isn't working correctly. Hope you get it figured out.
      10-23-2013, 07:11 PM   #6
gregthegr8
Admiral of the Fleet
gregthegr8's Avatar
265
Drives: Cars Usually
I've had the no key detected twice now when literally the key is 6 inches from the steering wheel and no phone or anything in sight. It's a really weird and temperamental system. But not a big deal, I am able to push buttons when it doesn't feel like working. The no key detected when trying to turn the car on though is a very disconcerting feeling.
      10-23-2013, 09:21 PM   #7
One35iMT
it seems it happens more in drivers side 95% fail
trunk and passenger side 70% fail
It never works when its in my pocket.
      10-23-2013, 09:22 PM   #8
One35iMT
when key fob is in pocket, every functions are not working open lock trunk even turn on the engine
i only put my key fob in my pocket
      10-23-2013, 10:18 PM   #9
PopsnBurbles
PopsnBurbles's Avatar
Drives: 135is :) 192/586
I've never had any issues with my CA except for not opening the trunk properly. Even without using the CA, opening the trunk is already an issue for me. So, I'm not completely blaming the CA for that. Well, who am I to judge? I'm barely hitting 2k mi.
      10-23-2013, 10:34 PM   #10
135ivert
Drives: E88 135i,E70 X5M,E93 M3
Doors - never a problem. Starting - only once or twice - maybe I feel like it is a fob battery issue. It is a daily driver, and I replaced the battery with some $0.30 cheapo chinese special. I took the fob out of my pocket and it started immediately. Trunk - 50/50. If I take the fob out of my pocket it's 100%. Not reliable data, I know, but food for thought.
      10-24-2013, 08:21 AM   #11
e36addict
Drives: 2013 X1 35iX
I find that actually using my key is very easy..lol.. But really, the cars battery has nothing to do with CA functionality. Sounds more like you have an issue with the reciever antenna located near the 3rd brake light. Very common issues with all CA equipped cars.
      10-24-2013, 06:02 PM   #12
Walter K
Walter K's Avatar
23
Drives: 128i (white)
My CA just started acting up this week. Thought is was the battery until I went to the passenger side also the trunk and it worked. Went back to the driver side and no good. Repeated this process once more just for consistency and still didn't work. I can still lock and unlock the doors with the key fob but it sucks after getting used to the feature. Hope it's not a sign of things to come.
      10-24-2013, 08:44 PM   #13
CAVU
CAVU's Avatar
Drives: '16 F87 M2
Good news is that the touchscreen-compatible gloves I bought seem to work well with my CA. Or said another way, my CA isn't acting up any more often when I use the gloves...
      10-24-2013, 09:53 PM   #14
Walter K
Walter K's Avatar
23
So you have to look cool to open your car? Nice
      10-25-2013, 12:40 AM   #15
One35iMT
Dealer quote me that everything is working fine, but battery.
That's why i spend $150 diagnostic fee for nothing!
I hope they replace the antenna...
      10-25-2013, 04:19 AM   #16
Walter K
Walter K's Avatar
23
I found this on an e90 forum. This is the service report of an actual fix for the comfort access issue.
      10-25-2013, 07:59 PM   #17
dtwyim
dtwyim's Avatar
Drives: BMW no more
FWIW, I have 2008 with CA, never had any issues. Replaced the battery in the key fob once so far.
Hopefully I did not just jinx myself.
      10-25-2013, 09:05 PM   #18
CAVU
CAVU's Avatar
Drives: '16 F87 M2
What does wearing gloves when it's freezing outside have to do with looking cool?
      10-25-2013, 09:07 PM   #19
CAVU
CAVU's Avatar
Drives: '16 F87 M2
Thanks for this info… it may come in handy if/when I bring up the issue with the service department.
      10-25-2013, 11:11 PM   #20
lastMleft
lastMleft's Avatar
Drives: e92 M3
Recently had similar issues with my fob, I had my car in for the battery cable recall and I had the dealership check my fob they found my fob to be faulty, so I had to buy a new one
      10-26-2013, 07:02 AM   #21
Walter K
Walter K's Avatar
23
Three potential solutions, very nice. Module by A pillar, receiver by 3rd brake light and faulty fob.
I think mine may be the module by a pillar cause on one side it works and not the other. I don't even hear the mechanical sound when I hold my hand next to the driver side door to open or close.
      10-26-2013, 12:30 PM   #22
Kracken
Drives: 2011 AW 135i DCT M Sport
Originally Posted by yongsange View Post
Here is my story,
Im in the same boat with my CA- it's intermittent.
My factory warranty expires in a year and so far they (BMW) have just changed key fob batteries with no real improvements. I have a year to bug em about it and get it fixed.
Sometimes car wont even start with key in pocket and all doors and trunk are the same. I already have a new battery I had to pay for so they cant blame that.
They mentioned my window tint may have to blame but it was intermittent before the tint went on.
I can already see them trying to wiggle out of fixin it before warranty expires...
good luck with your saga
2011 AW 135i
