07-11-2016, 09:07 AM | #1 |
Rep 74
Radiator Fan Removal DIY Request
I was showing my 2012 135 to my brothers this weekend and they noticed that the radiator fan might be making some ticking noises when the AC is on (only when the fan is blowing super hard).
It was a really hot day, 95+ and the fan was winding up pretty hard with the AC on, when it was blowing hard it we heard the noise (sounded like it was coming from the fan). As soon as I turned AC off the fan slowed down considerably and the sound went away. I'm wondering if the fun is starting to wobble a bit when it's winding hard. Anyway, is there some DIY out there on removing the radiator fan? I'd like to take it out and see if there is some looseness in the cowling. |
07-11-2016, 02:46 PM | #3 |
BMW Master Tech
587
Rep 850
Drives: E30, E36, E82, E90, F10, F80
Garage List 2015 Aston Martin V ... [0.00]
2010 Lamborghini LP ... [0.00] 1985 Alpina C2 2.7 [0.00] 2017 BMW M3 [0.00] 2008 BMW 128i [10.00] 2013 BMW 135is [0.00] 1992 BMW 325i [0.00] |
Everything is done from above. The only reason you may need to get under the car is to unbolt the oil cooler from the fan shroud.
EDIT: Nevermind, you have an N52. Pull that sucker right out the top.
135is #502 of 586
BMW LED Performance Wheel | OEM FULL Carbon Fiber | E9X M3 Gauge Cluster | E9X Exterior Mirrors | E9X M3 Full Suspension | E9X M3 Diff | PT-CAN2 Enabled | Bilstiens | Michelin PSS's | NBT Navigation Retrofit with Touch Pad |
07-11-2016, 06:21 PM | #4 |
California-bound
383
Rep 1,480
The fan comes out from the top of the engine bay. You'll likely need to jack up the front end and remove the undertray to reach the bottom fasteners holding the fan assembly onto the rad.
Willow Springs - Big Willow (CW): 1:35.8 - 3/31/18 |||| Buttonwillow #13 (CW): 1:59.3 1/27/18 https://www.facebook.com/JakeStumphRacing |||| http://www.youtube.com/user/RaceMeMZ3 |
