      11-22-2017, 02:30 PM   #1
RoscoT
Drives: 128 Convertible
Trunk Light Meltdown
When I went to change a burnt out light bulb in my trunk I found the light housing was melted (see pics). My Bimmer is a 2008-128i.The bulb I removed was a 12v 10W. Maybe once upon a time, someone (previous owner) put in the wrong bulb or the trunk had been left open for a long time. When I put in the new bulb it was very hot the touch within a few seconds. Is this normal? I'm worried about potential fire. Is there something going on that I should be concerned about. I did confirm that the light goes out when the trunk lid is closed. Thinking of replacing with LED. Any comments in this regard would be appreciated.
      11-22-2017, 02:55 PM   #2
doogee
doogee's Avatar
Drives: '08 M3, '97 328is
Strange, 12v 10watt is correct.
      11-22-2017, 03:13 PM   #3
thetastelingers
Master Baiter
thetastelingers's Avatar
1949
Drives: 2009 E92 M3 BOOSTED
Replace with LED.
      11-22-2017, 11:35 PM   #4
chris_flies
I enjoy this car too much
chris_flies's Avatar
Drives: Enthusiastically...
2009 BMW 128i  [5.00]
The hot-to-the-touch is normal, melting could just be that the bulb wasn't seated right, or that, as you said, the trunk was left open for a while. LED's can't hurt, unless you're a credit card, they use less energy, meaning you don't have to worry as much about draining your battery by leaving the trunk open.
2009 130i 6-Speed Coupé | Monaco Blue with Black Sensatec | chris_flies' 128i Build
"To disarm the people...was the best and most effectual way to enslave them" -George Mason
-NA Supremacy Propagandist-
      12-09-2017, 01:44 PM   #5
RoscoT
Replaced factory light with LED light C/W housing from iJDMTOY.com for $18. Fit was perfect and light is very bright. Great solution to a potential fire in the trunk if the light is erroneously left on for an extended prior of time.
      12-09-2017, 01:48 PM   #6
mackeroni
Former Opel GT Pilot
mackeroni's Avatar
Drives: 2011 135i, AW, CR, 6MT
If I leave my trunk open, the light goes out automatically after a bit. Need to look elsewhere for root cause of melted light cover.
So, that's it. I am doomed. There is no patch, no methadone, no substitute. Curse you BMW. Curse you and your seamless power delivery. Curse the incredible sense of road feel. Curse the comfort, the luxury, the envious looks from the masses. I am... hopelessly addicted.
