      04-15-2010, 02:01 PM   #1
Grillo
Drives: AW 135i
what's the largest size we can safely mount on the stock 18" wheels?
hi
just want to know what's the largest size we can safely mount (w/o rubbing) on the 135i stock 18" wheels? do hankook v12 evo 265/35/18 rub?
thanks
      04-16-2010, 07:26 AM   #2
Kokanator135
Kokanator135's Avatar
Drives: '08 135i
      04-16-2010, 08:25 AM   #3
arrutled
arrutled's Avatar
59
Drives: Olsa
255/35 max rear 235/40 max front
AW 135i w/ blackette, performance short shift kit, BMW alarm, Performance rotors, APEX ARC-8 wheels, Direzza Star Spec 235/275, Dinan stage 3 suspension, M3 wishbones/tension rods/front sway/rear subframe bushings and thats all folks!
      04-16-2010, 02:52 PM   #4
DBFIU
Crack Addict
DBFIU's Avatar
Drives: Fast
Send a message via AIM to DBFIU
I hear people say 225 max front, some say 235 max front. Dont know who to believe anymore.
2009 - Titanium Silver - Steptronic - 135i - Nasty
      04-16-2010, 03:17 PM   #5
_dopehead_
Denmark
Drives: BMW 135i AW 2008
From what i have read 225 is the safe bet, 235 would be dependant on the specific tire, as apparently all tires are not the exact width they state on the tire.
      04-16-2010, 03:42 PM   #6
bradford
Drives: 2008 SGM 135i
Is that fender-clearance related or strut / spring perch related?
      04-16-2010, 04:08 PM   #7
Eddy@ApexRaceParts
223
Drives: E30 M3, F10 M5
on the stock wheels it's both. 235 is close to both sides.
      04-16-2010, 04:20 PM   #8
arrutled
arrutled's Avatar
59
Drives: Olsa
If you search hard enough you will find posts made by member bdh21 who has 235/40 direzza star specs (wide running) up front. He also happens to be a close friend of mine who I will see tomorrow. Believe it!
      04-16-2010, 04:36 PM   #9
DBFIU
Crack Addict
DBFIU's Avatar
Drives: Fast
See now I'm worried. I want to get star specs but some people have said 235s in the front are too wide... I really want 235s though. Does your friend experience any rubbing at all? Stock suspension?
      04-16-2010, 07:04 PM   #10
arrutled
arrutled's Avatar
59
Drives: Olsa
He said it rubbed once or twice. Never while autocrossing though. only at this one place on the way to his gf's a dip and a turn at the same time.
      04-16-2010, 08:59 PM   #11
xxx_mina
Outlaw
Drives: 2015 M4 JB4
2015 BMW M4  [4.67]
2010 135I  [0.00]
2007 335i  [0.00]
who cares about the front.... how big can you go in the rear??? i wanna do like 275 for drag racing... you think i will have any issues??? i went 265 with the 335i... can i do 275 on that rim and on the 135i?
I just bought a spare set of rear Rims for this... so dont worry iam not gonna drive everyday with em.... just when i go to the track...
Mina
      04-16-2010, 09:09 PM   #12
scorcherjf
scorcherjf's Avatar
Drives: 2008 135i
2008 135i  [0.00]
Mina
lol i guess if you're not concerned with turning that's ok =)
i think my next set of rims will be the apex ones and i'll try to do 245 front and 275 rear
      04-16-2010, 09:20 PM   #13
arrutled
arrutled's Avatar
59
Drives: Olsa
I have a 275/35 on the Apex arc-8 rear 9.5 et 62
      04-16-2010, 09:21 PM   #14
xxx_mina
Outlaw
Drives: 2015 M4 JB4
2015 BMW M4  [4.67]
2010 135I  [0.00]
2007 335i  [0.00]
so 275 rear can be done on stock rims????
isnt stock like 8.5?
      04-17-2010, 12:47 PM   #15
Grillo
Drives: AW 135i
Mina
+1
i want to know if V12s 265/38 on the stock rim wont rub.
      04-17-2010, 01:36 PM   #16
arrutled
arrutled's Avatar
59
Drives: Olsa
Do not put 275 on stock rims! Apexraceparts created a custom one series wheel which allows us to run up to 275 out back. your best bet is 255 on stock.
      04-17-2010, 09:03 PM   #17
LA-Bimmer
Drives: 2012 E92 335i
225 F 255 R Star Specs work great and are a tremendous improvement over the RFTs. I would not want to try 235s up front. Why risk rubbing issues vs. going with a great tire that will perform well. I'd put 225 Star Specs up front against most any other 235s any day.
      04-18-2010, 02:13 AM   #18
xxx_mina
Outlaw
Drives: 2015 M4 JB4
2015 BMW M4  [4.67]
2010 135I  [0.00]
2007 335i  [0.00]
What happens when you put 275 or 265 on stock rims??? why cant i do it???
Mina
      04-18-2010, 04:14 AM   #19
aerobod
Car Geek
aerobod's Avatar
Drives: Caterham R400, M240i, Golf 7 R
Mina
1. The sidewall of the tyre will be angled in too far, risking the rim pinching the sidewall and damaging it on bumps.
2. The tyre will be very difficult to mount.
3. The tread will not be in full contact with the road due to it being curved, as the sidewalls are pulled in too tightly.
4. 265/35-18 and 275/35-18 tyres are a bit tall for the 1-series, exacerbating clearance issues, 265/30-18 or 275/30-18 tyres don't seem to be available sizes.
5. Manufacturers only support the fitting of 215/40-18 to 255/35-18 tyres on the stock rear 8.5" rim. The stock front 8" rims will fit tyres from 205/40-18 to 245/35-18.
      04-18-2010, 04:48 PM   #20
Pol
Nobody is perfect !
Pol's Avatar
Belgium
556
Drives: M2 (MG) M DCT - April 2016
Stock fronts = 7.5"
      04-18-2010, 05:15 PM   #21
aerobod
Car Geek
aerobod's Avatar
Originally Posted by Pol View Post
Stock fronts = 7.5"
Sorry, I was thinking of the Z4 stock sizes.
1-series staggered 7.5" stock fronts will take tyres up to 225/40-18 to stay within manufacturers specifications.
      04-22-2010, 02:42 PM   #22
xxx_mina
Outlaw
Drives: 2015 M4 JB4
2015 BMW M4  [4.67]
2010 135I  [0.00]
2007 335i  [0.00]
is this all theories or has someone actually tried 275/35-18 and failed miserably????
also these will be track(drag) tires only.... so iam gonna be running them on low pressure (should fix curve issues) and i will defenetly look out for these problems before i put them on the car..... also my car is stock hight... so taller tires shouldnt be a problem in anyway...
just give me a week and i'll tell you if they are good or not... i've done 265/35/18 on my 335i with no problem... so we'll see what happens with 275/35/18....
