08-19-2011, 12:43 PM | #1 |
Rep 316
1M Headlight shake
Anyone else have a lot headlight shake over bumps? I have noticed my light pattern jiggles more than I would expect when going over bumps. Just wondering if anyone else has seen this type of thing.
08-19-2011, 01:25 PM | #2 |
CW2
27
Rep 440
Drives: 1SMC - traded away
I would think that's a good thing .
The adaptives have some change in pitch. My X3 seemed a little bouncy at times but always evened out.
Good-bye, ol' Paint...
08-19-2011, 02:41 PM | #3 |
Rep 355
Drives: a disturbed shark!!!
Garage List 2023 iX xDrive50 [0.00]
2020 X3 M Competiti ... [0.00] 2017 i3 REx (Sold) [0.00] 2015 X5 xDrive35d ( ... [0.00] 2015 M3 (Sold) [0.00] 2012 X5 xDrive35d ( ... [0.00] 2011 1M (Sold) [10.00] 2006 330xi (Sold) [0.00] 2002 X5 3.0i (Sold) [0.00] 1998 318ti (Sold) [0.00] |
Mine shakes quite a lot as well when driving over bumps/rough roads...
I inquired about it during the running service and the service adviser said it is normal because of the adaptive lighting and the stiff suspension... The explanation sounded logical, I hope they didn't just make it up to brush me off... |
08-19-2011, 02:45 PM | #4 |
Rep 5,018
Drives: VALNCYA
just the way they work unless they flop or drop off i wouldnt be concerned
08-19-2011, 02:46 PM | #5 |
Rep 1,668
Thanks for this thread..........I have the shakes too.........was a little worried that something was wrong.
But it seems normal I suppose, however I never ever noticed this in the M3....... |
08-19-2011, 02:49 PM | #6 |
Rep 22,992
My 135i also does this. If you do a search for "headlight wiggle, wobble or jiggle" you will find many posts. Basically I think its the suspension linkage sensors binding a little bit bc everything is new and tight. Over time... the "jiggle" goes away somewhat. Its normal function of the AHL (Adaptive Head Lights).
08-19-2011, 03:45 PM | #7 |
Rep 316
Thanks. Kind of a relief to hear others have similar experiences. I was just worried about blinding oncoming traffic or causing some damage to the headlights. I am going in for my 1200 mile service soon and wanted to see if this is something I should point out.
08-19-2011, 04:52 PM | #8 |
Rep 391
Drives: INTERLAGOS ZCP
Garage List 1990 BMW L6 (retired) [0.00]
2010 BMW 135i M-Spo ... [0.00] 2011 BMW 1M (adopted) [0.00] 1990 MERCEDES 190E ... [0.00] 2012 BMW M3 [1.00] |
Annoying, but normal. Although more noticeable than on my old 135i.
08-19-2011, 06:26 PM | #9 |
Rep 3,939
This is entirely normal...it's called HID flutter. The HID bulbs are long and thin, so they have a tendency to do this over rough bumps/roads. I believe this was done on purpose. Think about it: a rigid long bulb has higher chances of breaking than one that has the ability to flex a little (flutter). It's all in the manufacturing process and how the bulb gets attached to the base.
08-19-2011, 06:45 PM | #10 |
Rep 901
You could always test the lights to see if it's normal or excessive. Just turn the light switch to the ON position (all the way to the right) while driving over a bump during night and you should not get the wobble of the light adapting. It should stay straight and not bounce around. The far left position is Auto/Adaptive lights.
2011 VO 1M
08-19-2011, 06:53 PM | #11 | |
Rep 22,992
The "wobble" is when you go over bumps. Not when you turn left or right. I think its because if the sensors linkage to the suspension... its a ball and socket plastic linkage. When its new it tends to bind some - when it moves. In other words the linkage's movement isn't totally smooth. So the sensor gets a non linear signal, more like a jerking signal with spikes. This is what causes the "wobble" when going over bumps. After about 15K miles its much less. But still there to some extent. This is just how the system works. Btw... you guys ONLY get the AHL function when the headlight switch is in the AUTO position. When you manual turn teh headlights on... the headlighst always stay dead straight - they do not turn with the steerung wheel. That is WHY I always run with my lights in AUTO position/mode. I love my kurven-lichts! |
08-19-2011, 07:06 PM | #12 | |
Rep 3,939
08-20-2011, 11:34 AM | #13 |
Rep 965
May be a little of both, but this statement is true. I did an HID replacement/swap on my type-r in 2001 and I also got this effect after they were installed.
08-22-2011, 09:09 AM | #14 |
Rep 143
The reason you feel the wobbling is that the HID are so bright that it creates a sharp line in front of you.
I was so disturbed with that line wobbling on a highway at night, I decided to adjust the head light slightly upward. This has moved the sharp line to a little bit further, it doesn't bother me like before. There is a white plastic thing which you can turn by 6mm hex wrench or a plus driver as shown in the picture below. It is aiming way below horizontal, so it would not blind the oncoming traffic. Right side of the car left side of the car One turn (360 degrees anti-clockwise) was not enough in my case. Two turns (720 degrees anti-clockwise) was enough for me. Before After |
08-22-2011, 10:16 AM | #15 |
Rep 1,003
The flutter over rough pavement isn't a HID-specific thing and it has nothing to do with the auto-leveling. My car has halogen lights and they too shake over rough pavement and/or bumps. I've had previous cars, with and without HIDs, with and without auto-leveling, and some of them too had "shaky" headlights. It really has to do with the mounting of the projectors and/or reflectors in the headlights. If the tolerance is great enough, the projector/reflectors will actually vibrate over rough pavement. The lights purposely magnify the light and so that minute vibration at the projector/reflector level is very noticeable out in front of the car.
With the advent of the newer dynamic auto-leveling systems that many automakers are now using with HIDs, dealers and misinformed owners chalk the "shaky" lights up to the auto-leveling system doing its thing. I assure you, however, that is not completely true. I even had a car one time that I complained to the dealer about for this exact reason and the dealer told me it was the auto-leveling in action. Hmm, strange, why then did the lights vibrate when the car was sitting still and the cold engine (4-cylinder diesel with no balance shafts) at idle speed? Granted, this vibration could only be seen if parked very close to a wall with the lights on, but you can imagine that rough pavement would only amplify that. |
08-22-2011, 01:05 PM | #16 |
Rep 157
Perfectly Normal
08-22-2011, 01:23 PM | #17 | |
Rep 615
selfish drivers ftmfw
VO 1M - everything except sunroof
RIP BSM 135i 2009-2011 |
08-22-2011, 01:30 PM | #18 | |
Rep 22,992
Well... to be fair to KIYO bmw does aim the lights kind of low from the factory. As long as other drivers are't flashing him as he drives past he is most likely ok. I think KIYO tip is a good one to keep in mind. Because as we know sometimes the cars don't really get a thorough PDI - in checking the headlight hight specs. |
08-22-2011, 03:33 PM | #19 |
Rep 143
Your right. I might be one of the selfish owner. I will check if oncoming traffic flashes.
My 1M' headlight was aiming at just in front of me. So it was kind of dangerous on a highway. |
09-15-2011, 10:05 AM | #21 |
Rep 2,375
Haven't had the shakes myself but I recently noticed how low the lights were.
The Xenon's on my R53 Mini Cooper S were also set very low and my dealer adjusted them for me. Think I will make the request when the 1M goes in next. |
