11-29-2009, 11:53 AM | #1 |
Rep 5
Clutch delay valve?
Any thoughts on pro's & con's of replacing the clutch delay valve with amodified one? I really hate the delay between shifts. Is it hard to install? Who could I have do it? BMW? What's a fair labor charge?
11-29-2009, 01:09 PM | #3 |
Rep 7,594
Drives: '19 M2C
Been discussed a million times. |
11-29-2009, 01:26 PM | #4 |
Rep 1,340
Drives: 2008 135i SGM MT
Garage List 1995 Acura Integra SE [0.00]
2008 BMW 135i [0.00] 2006 Porsche Cayman S [0.00] 1999 Toyota 4-Runner [0.00] |
+1000
SEARCH............."Clutch Delay Valve" or "CDV"
2008 135i SGM |
11-29-2009, 07:12 PM | #5 |
Rep 3,547
It is an obstruction in the hydraulic line for the clutch of a manual transmission BMW. It keeps the clutch from operating as abruptly as it otherwise would. I think it helps smooth out shifts nicely and apparently BMW likes it to minimize damage to the clutch from abrupt operation. Some people think they can shift a little faster without it. I think my bimmer shifts smoother than any of the many other manuals I have driven over the years and I suspect this valve is one reason that is the case.
Jim
11-30-2009, 02:52 AM | #6 |
Rep 930
The clutch delay valve is actually designed to cause more damage to the clutch, not less. In doing so it prevents damage to the rest of the drivetrain such as the gearbox. The above comment is inaccurate.
When you drop the clutch very abruptly as you would when launching the car or driving in an 'enthusiastic' manner the CDV essentially vetoes that by not allowing the clutch plates to clamp shut instantly, thus slipping the clutch a little and avoiding shock to the drivetrain. Depending how often you drive 'enthusiastically' this will significantly shorten the life of the clutch. It also removes a lot of feeling from the clutch and makes it feel wooden and imprecise in my opinion. And by removing total control of the clutch action from the driver it does make it difficult to modulate gear changes, particularly at slow speeds and particularly from 1st to 2nd. I am not a fan.
2009 123D Coupe | Sedona Red | Black Boston Leather | Brushed Aluminium Trim | Tinted Windows | M-Sport Package | 6M | Comfort Access | Heated Seats | Navigation | Park Distance Front & Rear | USB | Bluetooth | Voice Control | Efficient Dynamics | Rain & Light Sensors | Xenon Lights
My blog: http://urbanemusings.wordpress.com/ |
11-30-2009, 07:35 AM | #7 |
Rep 10,176
I agree. Wouldn't it be nice if, when even given what to search for, that they didn't add to the thread beyond that? I think it makes people lazy, because even though they are given info on what to search for, somebody undoubtedly come along and reposts the information in that thread anyway.
11-30-2009, 07:42 AM | #8 |
Rep 1,340
And I wasn't trying to be mean with my direction/advice.
It's just that, knowing the ton of discussions on the CDV could not be duplicated here and if the OP wanted the answers to his/her questions that the search and past threads would be the most thorough way to get them.
2008 135i SGM |
11-30-2009, 07:49 AM | #9 |
Rep 10,176
Totally agree. I don't think there's anything wrong with saying that it's been talked about (a lot) before, and leave it at that. You even went the extra yardage to give search terms. No need to replicate entire discussion threads over and over.
11-30-2009, 08:09 AM | #10 |
Joint Chiefs of Staff
4912
Rep 115,980
The CDV is the best mod for the price on MT cars At 20.00 bux you can't go wrong. Install is simple but you need a lift to do it easily, so I had mine done at a local shop for 25bux I believe. Should take only 15min..
Mike |
11-30-2009, 09:22 AM | #11 |
Rep 677
and when you go to the shop mike, what do you ask them?
i want you to bleed out my clutch and replace my cdv? am i going to cause some lifted brows when i ask that?
Follow my car/ life via Instagram @rdauito
2011 E82 1M #215 of 740 http://www.1addicts.com/forums/showthread.php?t=877009 |
11-30-2009, 07:17 PM | #12 | |
4912
Rep 115,980
If they can't do it for you or have no idea of what you are talking about then its time to find a new shop. Mike |
12-09-2009, 08:06 AM | #14 |
Rep 84
i've been looking for a DIY, but i can't seem to find it. Do you know where, if so ,can you send me the link. If not i guess i'll just go find a shop.
12-09-2009, 08:42 AM | #15 | |
Rep 4,528
Drives: M2 CS
http://www.1addicts.com/forums/showt...hlight=CDV+DIY |
12-09-2009, 09:37 AM | #17 |
Rep 10,176
Very true, but you'd have to let the fluid pour out for that to happen. I definitely lost some fluid doing that DIY, but it was fairly inconsequential to the fluid level in the reservoir. I think the main reason for the fluid loss was having a DSLR in one hand.
12-09-2009, 09:46 AM | #18 |
Rep 279
Does the $25 bucks include the installation and bleeding the clutch? I ask because a shop quoted me $145 to replace the CDV with a modified one and to bleed the clutch.
12-09-2009, 10:31 AM | #19 |
Rep 825
I think $145 is a little steep. It took me about ½ hour total but you need ramps of jack stands.
2019 X3 M40i - Black Sapphire Metallic - Mocha Lather - 21" 718M wheels - Every option except Sun Shade
12-09-2009, 12:37 PM | #20 |
Rep 10,176
$145!!! Yikes. I did mine in less than an hour, including taking all of the pics and writing wrench sizes and number of bolts, etc... for the DIY.
With a lift, it's a 15 minute job, since you do not need to bleed anything, if you are the least bit careful. |
12-09-2009, 05:10 PM | #21 |
Rep 693
I just did my CDV with a modified one on the 135, the shifting now is some much better and faster.
Deff. worth doing, install time only took about 30 minutes from start to finish. I would deff. bleed it. i clamped the line no fluid leaked out, and when i bleed it air came out, cause of the new CDV has air in it when installed, takes an extra 3 minutes. excellent mod, wish i did it when i had my 335xi for 2 years. |
12-09-2009, 05:13 PM | #22 |
Rep 4,528
Drives: M2 CS
^did you buy a modified one or just modified the stock one?
