      05-15-2010, 12:46 PM   #1
jwellsiii
Drives: 135i SG 6MT
2010 135i  [0.00]
Do you run at the track without wheel caps?
I drove the front-right wheel cap off my ARC-8's at Thunderhill on Wednesday.
I see most cars with their wheel caps on at the track. Should I glue them in? Or run without them? The choice would be really easy if the center hub didn't rust so quickly.
      05-15-2010, 02:56 PM   #2
onefastman
Never had that problem or heard of it
      05-15-2010, 03:15 PM   #3
...on some cars its worse than others. I have seen some people install a ring on the INSIDE of the center cap and use hex allen set screws to keep the cap from coming off. But that is a lot of work for something that doesn't cost all that much to replace IF it ever comes off. or like you said just remove them prior to running the DE.
      05-15-2010, 03:56 PM   #4
HondaGoneRogue
They like my Swag...
HondaGoneRogue's Avatar
433
Drives: 15 GSM 435i GC
I lost my front driverside one at Las Vegas Speedway. I wonder if you can order Breyton caps seperately?
2008 AW 135i - Sold
      05-15-2010, 04:48 PM   #5
LA-Bimmer
Drives: 2012 E92 335i
Never had a problem. Maybe I need to push more
      05-16-2010, 01:51 PM   #6
Cisitalia
No fast lane bandits allowed
Cisitalia's Avatar
Drives: 2009 135i TiAg 6mt M-Sport
It's best to remove the center wheel caps and the air stem caps. Elimanates potential track fodder. Also removal of the air stem caps means you can check your tire pressures quicker as well.
