      02-20-2017, 04:55 PM   #1
bm49
Drives: 2012 135i manual, 2010 320d
Anyone know how to code out E82 135i e-diff in NSW/ACT
My 2008 E82 135i manual is fitted with a Quaife LSD and is regulary run on race tracks. Despite turning STC and DSC off I am still getting a loss of power when exiting corners.
The nanny effect is not as bad as having the DSC switched on but it causes a noticeable reduction in acceleration. A friend in a 130i recently followed me for a couple of laps and swore that he could tell where the e-diff intervened as he could see the pauses in motion and closed the gap each time. It is a real pest as running on R-spec tyres improves traction to such an extent that it is not dangerous to turn the nanny controls off. I understand that the re-coding can be done using NCS but I need to find comeone who knows how to use this program.
      02-20-2017, 05:56 PM   #2
1and1
Loves me some MHD!
1and1's Avatar
'09 135i  [10.00]
How to make your BMW actually fun- Electronic Diff Coding nannies
1and1
135i - E82.N54 2009 BSM - MHD / xHP / DCI, PR CP & 7.5" Race IC / N55 mid & Borla
      02-22-2017, 06:32 AM   #3
SIN-CAL
SIN-CAL's Avatar
Drives: 2009 E82 135i N54
2009 135I  [0.00]
Great post thanks 1&1
      02-22-2019, 06:19 PM   #4
Aus335iguy
Aus335iguy's Avatar
Drives: 2009 e92 335i MSport DCT
2009 BMW 335i  [10.00]
There's a thread on another forum that outlines how to add a M3/1M DSC to a non M car. I was a member of a group that worked to put M3 DCT drivelogic on a non M N54 car and it all works. You'll likely need the DSC, maybe a steering angle sensor and some tricky coding. If you want more info let me know.
Aus.
When you doppelkaplung you doppel your fun.
      03-25-2019, 11:22 AM   #5
flinchy
Drives: E82 135i
You can do it with an app now - bimmergeeks. Makes it 10* easier than ncsexpert (which isn't all that hard, but can take hours to get the bloody software working with the right combo of cable/laptop/VM etc..)
      03-25-2019, 10:17 PM   #6
135i2
Drives:
Protools is the simplest way to code out E-diff
https://www.bimmergeeksprotool.com/
135i - RHD Bottom Mount Single Turbo - GTX3584RS
