09-30-2017, 04:44 PM | #1 |
![]() 7
Rep 30
XhP Trans Flash Ozzy users
Whoever is using XhP trans flash in Oz can I get some feedback from you guys.
What Stage you running? Good, Bad and the ugly. Anything I should be aware of before running it? Thanks |
10-01-2017, 03:01 AM | #2 |
![]() ![]() ![]() 106
Rep 419
Do it, you wont regret it. Transforms the auto to something akin to what it should have been from factory.
ST stage3 flash.
135i - RHD Bottom Mount Single Turbo - GTX3584RS |
10-01-2017, 05:42 AM | #3 |
![]() ![]() ![]() ![]() 54
Rep 472
Drives: Volvo S60 R-Design Polestar
D is still shit. No one can do D shifts like OEM. I don't reckon that M shifts are as good as Alpina tbh. But. I have heard that they are better for the car as they drill down into more parameters than the Alpina.
Everything comes at a cost. |
10-03-2017, 11:35 PM | #4 |
![]() ![]() ![]() ![]() ![]() 68
Rep 853
I was keen to get this but I am now worried that my transmission is f@cked.
Twice now Over the past week I have turned onto an expressway and floored it only for the rpms to rise but no real acceleration until about 5000rpm. |
10-04-2017, 04:12 PM | #8 |
Rep 853
Oil, coils and plugs replaced about 1,500kms ago. Just had a walnut blast about 500kms ago. 88,900kms on clock and running cp, dps and Wagner fmic.
No cel or error codes either. |
10-04-2017, 11:49 PM | #13 |
![]() 904
Rep 1,004
xHP isn't cheap, but it's one of the best mods I've done.
I've always used the manual shift paddles because I hated letting the gearbox do its thing, but "S" mode in the xHP Stage 3 v1.4 is amazing. Truely amazing, I've never seen an auto-trans that comes close. It's always in the right gear for spirited driving, rev-matches on downshift perfectly and shifts way faster than I could throw a stick. |
10-06-2017, 11:37 PM | #14 |
Rep 853
My trans is getting worse. Hesitation when taking off from stop lights and uneven power output, especially when cold. Booked it in for a fluid and filter, hopefully it sorts it out. Really want to get a xhp flash on there but would be a likely toast trans if I did now.
10-07-2017, 03:47 AM | #15 |
![]() 389
Rep 2,186
Reset the trans adaptations after the fluid change and drive around slowly for the first 50km to let it adapt to the new fluid
Then flash the trans with xhp and let it adapt for 50 km again If anything helps this procedure will otherwise you might be up for a new box Last edited by martymil; 10-09-2017 at 05:05 AM.. |
