      11-04-2017, 08:44 AM   #1
Rajvosa
Drives: E92 M3
MHD tune on stock-ish 1M
Hi guys,
I’m running a Wagner Evo 1 performance IC and VRSF charge pipe.
Rest of car is stock.
Prior to doing FMIC I was running stage 2 tune and have now switched to Stage 1+. Just wondering what others are doing with same mods?
I’ve tried stage 2+ and it’s more power definitely but it’s quite harsh when I go from WOT to releasing accelerator pedal.
      11-05-2017, 07:16 PM   #2
CarJunkie
CarJunkie's Avatar
Drives: e82 1M, f87 M2cs
2020 M2cs  [0.00]
2011 BMW 1M  [0.00]
I run stage 2+ with my mods, biggest difference being the midpipe which deletes the secondary cats. Behavior is good, logs look good. I run the 91 octane map routinely since the standard pump gas here is 92 e10, but I have 100 octane available nearby and have blended to run the 93 and 95 octane maps, which obviously make more power. Those logs also looked good, no trouble meeting boost target or load target.
ayao643.00
      07-31-2018, 11:42 AM   #3
IZSL07L
Drives: BMW 1M
I heard midpipe doesn't actually affect hp
      07-31-2018, 11:48 AM   #4
The Wind Breezes
Drives: 135i N55 DCT
Why would you propagate something you HEARD but have no evidence for or experience with?
Also, removing one or the other set of cats is pointless, since you will make the car non-emissions compliant by doing so...might as well go all the way. You should remove remove ALL the kitties for optimal gains. If a cat works, it's necessarily restrictive. The same applies to the muffler but it's considerably less restrictive and also necessary if you want to drive the car hard on the street without getting the wrong attention.
Plus you won't get the awesome smell of real exhaust without being catless. That's one of my favorite parts of combustion engines.
      07-31-2018, 09:50 PM   #5
IZSL07L
Drives: BMW 1M
From what I read, the person who posted the comment did dyno runa on both n54 and n55 pipes back go back and hp was 1hp difference. Have you done Dyno run back to back?
      08-04-2018, 09:10 AM   #6
CarJunkie
CarJunkie's Avatar
2020 M2cs  [0.00]
2011 BMW 1M  [0.00]
Corection to my above post....about 3 months ago I switched to MHD stage 1+ (V8 beta). Overall performance seems similar. Part throttle drivability is definitely better, especially moderate boost and post shifts.
      08-04-2018, 10:34 PM   #7
Rajvosa
Drives: E92 M3
Since starting this post I’ve also added catless DP’s and am running stage 2+ (V7). Have tried V8 but seems generally not as strong or aggressive as V7.
      10-13-2018, 11:18 AM   #8
E30 Racer
E30 Racer's Avatar
Drives: '11 1M, '09 335i M Sport
Originally Posted by Rajvosa View Post
Since starting this post I've also added catless DP's and am running stage 2+ (V7). Have tried V8 but seems generally not as strong or aggressive as V7.
Mind posting a log?
      10-13-2018, 11:51 AM   #9
Rajvosa
Drives: E92 M3
Originally Posted by E30 Racer View Post
Mind posting a log?
havent got the logging module. keep meaning to get it one of these days.
      10-13-2018, 11:56 AM   #10
E30 Racer
E30 Racer's Avatar
Mind posting a log?
Logging is highly recommended. You really learn a lot reviewing the data you collect, and it's nice being able to make sure everything is indeed OK.
