      04-13-2018, 09:53 AM   #1
hunterl41
hunterl41's Avatar
Drives: 2011 1M
2011 BMW 1M  [10.00]
upgraded clutch on sale at ECS
Just and FYI... If anyone is in the market for the F10 550i upgraded clutch for your 1M they appear to be 30% off at ECS right now. Figured I would pick one up now and just shelve it until that fateful day I need to replace mine.
https://www.ecstuning.com/b-genuine-...n/21207603248/
      04-14-2018, 05:42 AM   #2
E30 Racer
E30 Racer's Avatar
Drives: '11 1M, '09 335i M Sport
https://www.bmwdirectparts.com/oem-p...te-21207603248
This *appears* to be the same kit, for less money, from a dealer (although you'll probably want to confirm it comes with the hardware).
      04-26-2018, 10:22 AM   #3
CarJunkie
CarJunkie's Avatar
Drives: e82 1M, f87 M2cs
2020 M2cs  [0.00]
2011 BMW 1M  [0.00]
I am very happy with this clutch, chirps tires on 1-2 shift with 500+ft-lb at the wheels. (Those are BFG rival in 275 width, so plenty or grip!) The stock clutch slipped under same conditions.
I had a slave cylinder failure shortly after install. Our slave cylinder has a plastic housing and the heat from my failing/slipping stock clutch probably deformed it. Its a cheap part and easily swapped during clutch replacement. For peace of mind, consider replacing the slave, especially if you have been driving with a worn clutch for a while. I think the part itself was $110, and doubt there is much labor difference when doing the whole clutch.
      04-26-2018, 11:24 AM   #4
hunterl41
hunterl41's Avatar
Drives: 2011 1M
2011 BMW 1M  [10.00]
Good to know thanks. Do you have the part # for the slave cylinder?
      04-26-2018, 02:12 PM   #5
CarJunkie
CarJunkie's Avatar
2020 M2cs  [0.00]
2011 BMW 1M  [0.00]
I will look tonight.
      04-26-2018, 02:52 PM   #6
Rikx1M
MSgt (ret)
Rikx1M's Avatar
Drives: VO 1M #739/740
on the site it says it doesn't fit 1M..are you sure it fits our cars?
      04-27-2018, 08:50 AM   #7
CarJunkie
CarJunkie's Avatar
2020 M2cs  [0.00]
2011 BMW 1M  [0.00]
Slave cylinder part# 21 52 6 785 964 Cost $99.45
      04-27-2018, 08:56 AM   #8
CarJunkie
CarJunkie's Avatar
2020 M2cs  [0.00]
2011 BMW 1M  [0.00]
BMW Part# for F10 550i clutch I am using (ECS will usually reference the manufacturer part# so you can verify):
Clutch: 21 20 7 603 248
ISA screw (6): 11 22 7 520 706
Insulated tumbler: 80 90 2 285 597
      06-29-2018, 04:55 PM   #9
schmick325
Drives: 2012 BMW 1M
Yes it fits 1M. I have one in mine, its great
