03-19-2016, 10:07 AM | #1 |
Rep 434
Changing Spark Plugs Today - What Should the Gap Be?
Morning fellas
As the title states, I'm changing the plugs today with BMW oem replacements and I'm sure they are gapped already, but is that gap sufficient for a JB4 tune? What should the gap be? Thanks |
03-19-2016, 10:48 AM | #2 | |
Rep 195
OEM plugs are fine for jb4 tune. I was FBO with them. Not sure about gap, but they're 3 prong plugs so not sure if you could even adjust the gap if you'd even want to. I just recently switched to NGK plugs to help with rough idle after using OEM Bosch. Very happy so far. |
03-23-2016, 12:59 AM | #4 | |
Rep 888
Drives: 08 135i M Sport 6MT, 15 X3 35i
2015 Cosmic Blue Metallic Wrapped X3 35i ///M Sport Full 3M Vinyl Wrap | Flat Black Grilles |
04-20-2016, 01:19 PM | #5 |
BMW Master Tech
587
Rep 850
Drives: E30, E36, E82, E90, F10, F80
Garage List 2015 Aston Martin V ... [0.00]
2010 Lamborghini LP ... [0.00] 1985 Alpina C2 2.7 [0.00] 2017 BMW M3 [0.00] 2008 BMW 128i [10.00] 2013 BMW 135is [0.00] 1992 BMW 325i [0.00] |
They come pre-gapped.
135is #502 of 586
BMW LED Performance Wheel | OEM FULL Carbon Fiber | E9X M3 Gauge Cluster | E9X Exterior Mirrors | E9X M3 Full Suspension | E9X M3 Diff | PT-CAN2 Enabled | Bilstiens | Michelin PSS's | NBT Navigation Retrofit with Touch Pad |
04-20-2016, 02:00 PM | #6 |
Rep 1,575
04-22-2016, 11:05 AM | #7 |
BMW Master Tech
587
Rep 850
18Nm
135is #502 of 586
BMW LED Performance Wheel | OEM FULL Carbon Fiber | E9X M3 Gauge Cluster | E9X Exterior Mirrors | E9X M3 Full Suspension | E9X M3 Diff | PT-CAN2 Enabled | Bilstiens | Michelin PSS's | NBT Navigation Retrofit with Touch Pad Last edited by Downeaster1; 05-02-2016 at 07:00 PM.. Reason: I was wrong. |
06-27-2016, 03:54 PM | #9 |
1Addict
3233
Rep 7,894
OEM is fine for mild tune. If pushing things up towards 100hp beyond stock (or beyond), I'd recommend going colder on the plugs.
