      10-08-2019, 04:53 PM   #1
cmcgonag
Drives: 2019 Cayenne Turbo - 2011 1M
Intercoolers that fit without ANY Cutting
Is the Wagner EVo 1 the only intercooler that doesn't require ANY cutting or does the EVO 2 actually fit? Any others?
      10-09-2019, 12:04 AM   #2
1'M Blue
Oman
255
Drives: 1M
I believe ETS 5" IC also doesnt need cutting
      10-09-2019, 05:58 AM   #3
E30 Racer
E30 Racer's Avatar
Drives: '11 1M, '09 335i M Sport
Yes, but I believe the clamps holding the factory connections must be cut off.
      10-09-2019, 06:39 AM   #4
Soterios
BXR
575
Drives: 2012 135i
I installed the "needs no cutting" stepped VSRF intercooler. I had to cut a corner support out of the passenger side plastic. I was annoyed, but it's not something you would ever see and it's not going to hurt anything.
I've read posts about that same intercooler where people didn't remove any material.
      10-09-2019, 06:28 PM   #5
MechE
Drives: 2011 1M
The Forge intercooler required zero cutting and works with the factory fittings.
      10-10-2019, 09:47 AM   #6
nachob
Is that from personal, first-hand knowledge or from their advertisement?
Thank you.
      10-10-2019, 10:59 AM   #7
christofis135i
Drives: 2011 135i White/Red
Function >> form
      10-10-2019, 12:13 PM   #8
MechE
Drives: 2011 1M
I installed the Forge intercooler on my car and it required zero cutting. One caveat, I did remove the flexible shroud that clips in front of the intercooler. I may have been able to squeeze it in, but it would have been a tight fit. It's a non-structural part, and because the Forge unit is larger than the OEM unit, the shroud is less critical to ducting air into the cooler. I suspect trimming this shroud would have allowed it to be more easily used, but I just left it off.
nachob2314.00
      10-13-2019, 08:37 AM   #9
1&done
1&done's Avatar
Drives: 2011 VO 1M
This, best FMIC if you're not going to cut. Quality is top notch.
Also, CSF makes a plug n play FMIC, unsure if cutting is involved, -imported
https://www.turnermotorsport.com/p-5...iABEgL-SfD_BwE
///1M #643 of #740
      10-13-2019, 10:22 AM   #10
CarJunkie
CarJunkie's Avatar
Drives: e82 1M, f87 M2cs
2020 M2cs  [0.00]
2011 BMW 1M  [0.00]
FWIW, I had ADE install their FMIC. The shroud that directs air to the FMIC was cut perfectly to match the new profile. Nothing else required cutting and the shroud is a separate part that could be replaced if uninstalling.
      10-13-2019, 11:01 AM   #11
ayao
Thread killer
643
Drives: 1M
Re:CSF intercooler
https://www.1addicts.com/forums/show....php?t=1655101
      10-29-2019, 08:49 PM   #12
HP Autosport
Supreme Allied Commander
Drives: F80 M3
Correct!
