06-23-2016, 06:10 PM | #1 |
Rep 26
Whistling noise - please help!
I first noticed a whistling noise about a week after buying my car initially only could only hear it at about 70mph onwards however it's now noticeable from about 50mph. Appears to be coming from the centre air vent in dash although I'm not sure! Anyone had anything similar or could offer some advice on how to cure this as it's driving me nuts! Thanks in advance!
06-24-2016, 09:24 AM | #3 |
1Addict
3228
Rep 7,889
Never heard of this problem. Had a couple guesses as to what it might be for a 135i, but you have a 12xd, no clue.
06-24-2016, 10:31 AM | #4 |
BMW Master Tech
587
Rep 850
Drives: E30, E36, E82, E90, F10, F80
Garage List 2015 Aston Martin V ... [0.00]
2010 Lamborghini LP ... [0.00] 1985 Alpina C2 2.7 [0.00] 2017 BMW M3 [0.00] 2008 BMW 128i [10.00] 2013 BMW 135is [0.00] 1992 BMW 325i [0.00] |
May not necessary be drivetrain related. This sounds odd, but make sure that your side-view mirror housings are clean from debris. Wind passing over the mirrors (especially at highway speeds) can create disturbances that make high-pitched whistling noises.
Nextly, I would suggest getting a roll of painters tape and start taping rubber gaskets along the outside of the vehicle (possibly the windshield molding). Tape a new area, then road test. Repeat until you find the cause. This is all assuming it isn't engine/drivetrain related.
135is #502 of 586
BMW LED Performance Wheel | OEM FULL Carbon Fiber | E9X M3 Gauge Cluster | E9X Exterior Mirrors | E9X M3 Full Suspension | E9X M3 Diff | PT-CAN2 Enabled | Bilstiens | Michelin PSS's | NBT Navigation Retrofit with Touch Pad |
06-24-2016, 07:53 PM | #6 |
1Addict
3228
Rep 7,889
Ah, great idea on the taping gaskets outside the car.
06-25-2016, 01:44 PM | #7 |
Rep 79
I have this noise when the AC is not set to recirculate. see if it goes away when you manually set it to recirculate.
I think it is coming from an improper install of the shroud that holds the cabin air filters letting air bypass the filters and causing the noise, but I haven't had time to check it out yet. |
06-27-2016, 04:49 AM | #8 |
Rep 26
Have tried uploading a video but it keeps failing! I did notice than when i turn the air on the higher the air output the louder the whistle gets! cabin filter was my guess but haven't had chance to check yet!
06-27-2016, 05:09 AM | #9 |
Rep 22,992
Are you sure its not from your door seals? B-pillar ? But they usually make noise at much higher speeds. Unless your door/window is way out of whack.
