03-27-2012, 12:04 AM | #1 |
78
Rep 684
M-World Presents: KW Clubsport 3-Way for M3/1M
M-World Presents: KW Clubsport 3-Way for M3/1M Championship-winning performance for daily drivers M-World is pleased work in partnership with KW to install and review one of the first available 3-way kits in the world. Based on the championship-winning Competition 3-way, the Clubsport 3-way is a brand new line of coil over with near-stock ride quality on the street and Clubsport level performance on the race track. What the hell is 3-way? The Clubsport 2-way provides independent rebound and low-speed compression adjustments. The 3-way adds high-speed compression adjustments. On the street, the ride is much improved especially in cities with poor road conditions. The ability to significantly tone down the damping curve allows the car to ride very comfortably over large road imperfections such as potholes. On the track, 3-way offers enhanced stability and platform control over large bumps and curbstones, offering advanced drivers total control of the chassis. How are adjustments made? All damping adjustments are made using adjustment wheels. Rebound (18 clicks) is adjusted at the top of the shaft. Low-speed (7 clicks) and high-speed (14 clicks) compression are adjusted on the piggyback reservoir. Each click is clear and distinct. All changes can be easily made on the ground without taking any wheels off. How is the ride comfort on the street? We had Clubsport 2-way on the M3 prior to installation so we had an immediate baseline to compare against the 3-way. On the streets, with high-speed compression on softest setting, the car is now able to ride through large road imperfections very smoothly. The damper is able to completely absorb the impact without upsetting the chassis of the car. The ride quality is excellent and not unlike stock suspension. How is it on the track? We will be there shortly. Stay tuned.
04-03-2012, 10:41 AM | #3 |
Rep 515
Is this the "normal-regular" KW V3 Clubsport or smth above it?
"... on the smiles-per-mile charts, the 1-series M coupe can't be beat. It is a challenging piece, a triple-X-rated driver's machine for semi-professionals. Its handling balance provides an open invitation to indulge in latent oversteer, and provides an opportunity to separate the men from the boys. It is an absolute hoot on the track and an addictive plaything on your favorite twisty back road. "
04-03-2012, 10:54 AM | #4 |
Rep 1,700
V3's and Clubsports are affectively different to begin with, share the same shell but different valving, piston rods, adjustments etc, but clubsports only came in 2way adjustability, until now and the above being the new 3way set up..... feat high and low speed bump adjustments.
04-03-2012, 01:16 PM | #5 | |
Rep 515
04-04-2012, 01:21 PM | #8 |
Rep 515
04-28-2012, 03:21 AM | #10 |
Rep 119
Here are 2012 prices for Belgium, for the 1M:
Variant 3= 1961 euros Clubsport "3"= 2480 euros DDC= 2846 euros All of these are fully adjustable, including in ride height. I'll get the DDC, which is adjustable with a 3 position switch. Modes are Comfort, Sport and Track. In my view, the Clubsport is really firm and meant for trackday fans only ... |
04-28-2012, 01:19 PM | #11 | |
Kind of a big deal
301
Rep 1,674
Any curves (comparing to stock) anyone? |
04-29-2012, 01:06 PM | #12 |
Rep 119
Hi eeghie ! These are official KW Belgium prices including taxes. The price for the DDC is not including the W-LAN module that you can control with your I-pod, I-pad, etc.. (+300)
I'll get mine from: www.performance-store.com It's an independent BMW specialist in Nivelles, Belgium, which is a chassis geek and has a lot of experience installing and setting-up KW's . |
05-01-2012, 08:36 AM | #13 | |
Rep 1,700
05-02-2012, 01:46 AM | #14 |
78
Rep 684
Based on my experience, ride comfort is not just a function of spring rates, but also the damping curve. I've driven my E92 M3 without rear shocks (it has KW Competition with 1,000 pound/inch rear springs), and the rear axle was surprizingly smooth over large road imperfections.
The beauty of the Clubsport 3-way is that it allows the user to tune down the high speed damping circuit, and this will make a big difference in ride comfort/compliance. For those in Texas, this weekend we will have an M3 with Clubsport 3-way at Houston M Club's open track event.
