10-21-2014, 07:12 PM | #1 |
Rep 1,297
bmw performance exhaust bolt on?
Trying to figure out if I need a shop to install does it bolt right up to 135 and does the stock exhaust get cut or altered in some way?
2022 M3 xDrive Comp
2020 M2 CS (retired) 2018 M3 Comp (retired) 2015 335i (retired) |
10-21-2014, 07:17 PM | #2 |
Rep 1,293
The PE come with the axle back and a resonator delete Y-pipe. You can bolt the axle back on without modification. If you want to install the Y-pipe (which most people think is a must) you need to cut the mid pipes just in front of the resonator.
10-21-2014, 07:18 PM | #3 |
Rep 22,992
The PE kit comes with a y-pipe which deletes the mid pipe resonator. So yes, IF you install that. you need to cut off the old resonator and use the supplied clamps.
See post #90... http://www.1addicts.com/forums/showt...=797160&page=5 Dackel
10-22-2014, 08:41 AM | #4 |
Rep 1,297
thanks pal, this helps a bunch
how easy/costly would it be to revert back to stock if i decide to sell car
2022 M3 xDrive Comp
10-24-2014, 02:40 PM | #5 |
Rep 21
extremely easy although if you install the y-pipe then say good bye to the clamps (you will need those to re-install your original setup provided you kept it) of which BMW charges $122 to replace. Cost would be as cheap as buying a couple garage ramps to pull your car up on while you slide under and un-bolt.
