08-11-2015, 10:28 AM | #1 |
Rep 177
suspension for the daily driver (and more!)
i have been reading a great deal about suspension for the 128i. so i pose the question... what is a great and affordable set-up for the daily driver who would like to do a little track time on occasion?
i now run a 225/255 set-up on 18x8.5/9.5 wheels with +45 offset. the car is a 2008 sport pkg w/ 96k miles on the stock suspension. while the stance is "perfect" the car has tire rub in the rear when hitting dips in the road... at 70+ mph!!! so i need to address this... bump stops, stiffer springs??? 95% of my driving is combined city/hwy. i'd like to upgrade to a bilstein cup kit since i don't have the $$$ for coil-overs. i have also read the article from tc kline about upgrading bushings at the same time. for those in my situation, what is the "best bang for the buck?" |
08-11-2015, 11:01 AM | #2 |
Rep 998
really any aftermarket dampers will be a nice upgrade over stock. I DD my car and didn't want to go too low so I went with Bilstein HD/Swift Spec R and am very happy. I also wasn't concerned about adjustability though, which you may be. Biggest bang for your buck is really the subframe bushings tbh. If you can do the work yourself you can transform the car for like $200. A two piece design like the Whiltelines make the diy even easier.
I was able to get my dampers/springs/bushings for like $1,200-$1,300 since I did the work myself. That was the biggest savings right there.
Current: 718 GT4 6MT, F87 M2 6MT, F30 330xi, F25 xdrive35i Gone: E82 128i M-Sport, 997.2 911, B8.5 S5, 987.2 Cayman, W211 E550, E92 M3, B8.5 S4, 981 Cayman, E82 128i, E46 M3, Z4MC, Mk5 GTI VR6, MZ3R, C5 Z06, B5 S4, Volvo T-5R, Volvo 740Ti
08-11-2015, 11:06 AM | #3 |
1Addict
3233
Rep 7,894
Best bang for buck, especially if light track duty is on the docket, springs & dampers. Dampers are the weak link in these cars.
If you're already rubbing out back at stock height, what's your alignment specs? You may need more rear camber, and I would really recommend addressing those rear fender lips. Have this problem addressed before you do any suspension work. Then see how much room you have, and pick your parts accordingly. +45 is somewhat tough in the rear, especially with a big tire. I'd recommend changing up your wheel/tire setup and going 245 square for your 128i.
08-11-2015, 11:13 AM | #4 | |
Rep 6,196
Fix the problem, not the symptom. You need a higher offset rim in the back. |
08-11-2015, 11:26 AM | #5 |
Rep 177
Thanks everyone. I think the tire rub is due to stock sport suspension with 96k miles on it. The camber is all stock.
Best place to purchase bushings? Anyone know if an entire spring, shock, bushing kit can be bundled by one store? |
08-11-2015, 11:42 AM | #6 | |
1Addict
3233
Rep 7,894
Parts can be bundled if you find a retailer with them all in stock. Best way to get good prices is to shop around and ask for price matching. Best place depends on the bushings you want. Same rule applies to all the parts you select. If you list the parts you're interested in, I'm sure those of us with experience specific to those parts can chime in with pros/cons. Up to you to do the research though.
08-12-2015, 01:32 PM | #7 |
Rep 3,856
What about the BMW Performance suspension? If you're not looking for anything too crazy, I think that'd be great option.
08-17-2015, 04:06 PM | #8 |
Rep 505
I think MightyMouseTech hit it. Your rubbing is caused by incorrect offset. Stock offset on 18x8.5 rears is 52 if I remember correctly. As a side note- that's a lot of tire for the 128's power. I find my square 225's just right for this car especially at the AutoX, much less plowing of the front.
